[GPGT] PAP number 1 Chua Eng Leong went to residents to give masks despite not elect!
steven jialat
siloti
If you think it is a big deal that PA give out masks....
(1) do not confuse "administrative neutrality" -- PA funds comes from the PEOPLE. Not from PAP.
(2) Do a google on N95 masks. The key thing about N95 masks is that, there are many designs. Not all fit a same face. You need to find a correctly fitting one. The problem is more so in ASIAN face, because we have flatter facial anatomy as compared to AMDK. It has to have a correct fit, because any leak will make the mask useless.
I like to bring to forumers attention..... you know why Dr Chow (that cardiothoracic surgeon who died during SARS) he died not because he did not wear a mask, he worn one, but a wrong fit one.
Do you know all nurses and doctors in government hospital has to go for MASK-FITTING?? to ascertain at least 2-3 design that fits?
Mast fitting test..... the subject wear the mask, and in a close chamber, a perfume is sprayed, and the subject should not smell it. Otherwise it is not a correct fit.
So................ giving out N95 mask?? without mask-fitting test?? Try to bluff children??
Then.... N95 mask has to have a special way to wear, not just hook onto the face.
So, the whole exercise is a wayang....
Go google Mask-Fitting Test and Mask-Wearing instruction.
What is being done in the community centre?
People walk in, and collect two masks.
A wrongly worn mask is not mask at all !!!!!!!
Mask Fitting test.
http://www.uphs.upenn.edu/gme/pdfs/Fit Testing Procedure.pdf
(this one is protocol of University of Pennsylvanian)
We had another modification from CDC.
khroness
wah u so hardcore
Mask Fitting test.
[url]http://www.uphs.upenn.edu/gme/pdfs/Fit%20Testing%20Procedure.pdf
Ya the masks don't fit well but what to do?
No mask fitting possible...just fit as best we can and hope for the best.
gigigigi
Simi what to do?
Can plan better to really serve citizen instead of for wayang only.
Use tax money can not afford to buy diffrent masks to get better fit?
Can not mobilize GRC to conduct fitting + training?
Simi what to do?
So...you want to custom fit 3 million masks for citizens....:s22:
