HDTV, Digital TV and antenna discussion thread [consolidated]
kun1he2
The digital tv programs (HD5, dig5, dig8 plus digCNA) are transmitted through UHF chan 38. Yes, all four squeezed into one channel. This was the channel used for City and Sports chans many years ago (can any one remember?)
Hmm, doubt they are all squeezed into UHF 38...
According to these links at the right-hand side under "Terrestrial" section:
MediaCorp HD5 - Wikipedia, the free encyclopedia
MediaCorp Channel 5 - Wikipedia, the free encyclopedia
MediaCorp Channel 8 - Wikipedia, the free encyclopedia
MediaCorp Channel U - Wikipedia, the free encyclopedia
Channel NewsAsia - Wikipedia, the free encyclopedia
Only HD5 is UHF 38, while the rest are UHF 29 "multiplex carrying Mediacorp channels digitally".
Soul77
So you think I should just go with a standard antenna first before buying a better one?
Get a good powered antenna.
I'm using this EU673A and able to receive All the digital channels even though my room window is blocked by another building.
Page2 - Page 2
Some local neighborhood electric shop sell it (abt $38)
sunsetbay
Moderator
Moderator
you are right~ digital 5, 8 & CNA are on 538 MHz while HD5 is on 610MHz~ :s22:
mrsun18
@sunsetbay & kun1he2
Thanks. You are right. Finally found the official IDA document, in page 4 of >> http://www.ida.gov.sg/~/media/Files...es_and_Regulation_Level2/WST/WhiteSpaceTP.pdf
a list of current TV Band Licensed Users. This will dispel any remaining doubts. The part on DAB broadcast may already be out of date though.
There may be other interesting/useful information in the document.
Edit: The IDA document has moved >> http://www.ida.gov.sg/~/media/Files/PCDG/Licensees/SpectrumMgmt/SpectrumNumMgmt/WhiteSpaceTP.pdf
mrsun18
Page2 - Page 2
Or
If you take this as an opportunity to experiment/learn new things, then buy a simple one first from a shop (eg NTUC, Homefix, Chanllenger) which has a return policy. If you are on high floors there is a better chance of success. If it doesn't work out then pay the difference to change to a better one.
jtdcjtdc
jtdcjtdc - your condo no TV point?
sadly none. that's why i bought that rabbit V antenna. i tried positioning the antenna to my window so it has view of sky, i got one additional channel looks like TV7 of malaysia, but with same very poor/fuzzy unusable display. i don't get any singapore channel. i just use auto tuning (analog + digital). any idea why?
mrsun18
Reason is that all the signals blocked by surrounding high rise buildings. Not too sure whether yours is the old apartment type where individual units have to fix their antennae at the roof top or somewhere. Or do you have the scv point?
KerazzydaN
hey there, sorry if this isn't the right place to post cause i don't know where to.
on thursday my singtel fibre broadband totally went dead as it shows no service (red led). because of that, i can't use the house phone, miotv and the internet. called them up and their technician came and check the opennet port and told me there's high signal loss or something. but everything is fixed now.
before that, i used to get tv3, okto, cna, vasantham, indon channels + digital channels such as hd5 on both tv in my room and the living room. but now, there's totally no signal at all. can anyone tell me what's wrong or what should i do or who to call up ?
thanks for the help and sorry if i posted at the wrong thread.
mrsun18
@KerazzydaN
Need to tell us you are in HDB, pte condo or landed property?
Where you get the tv signals from?
KerazzydaN
@mrsun18
hey thanks for the reply.
hdb flat. got the signal from the normal wall socket. just out of the blue the signal disappear on the day my fibre broadband got no service.
mrsun18
ok. The situation is clearer now. It could be mere coincidence.
You can call HDB branch office to let them know that you have no tv reception and they will settle it for you.
On the other hand, if you flat is in the newer category where a utility box with patch panels is provided for connections of fibre, tv and phone cables, the ST people could have, but unlikely, mess up the connections.
Whichever way it is, the Branch Office will resolve for you. Good luck.
KerazzydaN
@mrsun18
hey thanks for the help. i already called hdb branch and they send down someone and adjust some stuff at the rooftop antenna. everything is fixed now. thanks !
mrsun18
@mrsun18
Wah, so fast. I suppose many others also called. Glad to be of help.
xonix
Can any HDTV with LAN or USB be converted into a smart TV via a LAN/USB wifi adapter ?
Or is there additional hardware requirement in the TV ?
arsene
Technically yes if the TV supports flash. However your viewing experience may differ depending on the processor speed of the TV. The best solution is still to link it to Android TV or PC for a better experience or external box.
chuppachop
Final technical specs of DVB-T2 receivers announced (silently) by MDA. Hopefully, TV makers like Sony, Panasonic etc. can rush to include the DVB-T2 tuners in their 2013 TV range very soon.
DVB-T2 Receiver Specification
jayz_sg
HDTV Digital Reception
Hi,
I have a Samsung Series 5 TV that has an in-built TV Tuner. I recently bought a Soundtech TVA-600 antenna to get digital signal. I am only able to receive HD5, Channel 5 Digital, Channel 8 Digital and Channel Newsasia Digital. How can I receive the other channels like Channel U, Suria, Vasantham etc?
Also I realized that if I really hang the antenna at the tip of the window frame, I can get extra 15 channels, but these channels cannot be viewed. It says channel scrambled.
Any ideas?
Thanks.
mrsun18
The other MediaCorp channels are not available in digital.
jayz_sg
Hi, thanks for the info.
If I get a VHF/UHF mixer, I will still not be able to get channels like okto and channel U which are in the UHF range right?
u0206397
SCV TV point, HDB antenna and FTA channels
Currently, my TV is plugged to the SCV TV point via an aerial coaxial cable with RF connector. But I'm not subscribed to any StarHub TV or SingTel mioTV. So can only receive those free-to-air (FTA) MediaCorp's channels (5, 8, U, CNA).
In this case, the signals for the MediaCorp's channels (5, 8, U, CNA) are coming from StarHub or the HDB antenna? The signals are analog and of standard definition (SD) only I suppose?
Channel 8, U and Okto are OK with clear image. However, for Channel 5 and CNA, my TV has noticeable horizontal bandings: alternate thick lines 1 or 2 inches thick of different brightness. A repeated pattern of a brighter line, followed by another darker line stripe. Anyone experiencing this? Tried playing with the TV settings but nothing helped. Poor reception, weak signal, caused by coaxial splitter or TV problem?
Years ago in the 90s, I thought HDB forced everyone to migrate to SCV TV point, and the antennas were deactivated or no longer usable. Is this correct?
Somehow my connection is able to receive the Malaysian RTM1 channel, but very noisy and barely watchable. But some people reported that the SCV TV point should not be able to receive RTM1. :s11:
