- Jul 3, 2000
Currently, my TV is plugged to the SCV TV point via an aerial coaxial cable with RF connector. But I'm not subscribed to any StarHub TV or SingTel mioTV. So can only receive those free-to-air (FTA) MediaCorp's channels (5, 8, U, CNA).
In this case, the signals for the MediaCorp's channels (5, 8, U, CNA) are coming from StarHub or the HDB antenna? The signals are analog and of standard definition (SD) only I suppose?
Channel 8, U and Okto are OK with clear image. However, for Channel 5 and CNA, my TV has noticeable horizontal bandings: alternate thick lines 1 or 2 inches thick of different brightness. A repeated pattern of a brighter line, followed by another darker line stripe. Anyone experiencing this? Tried playing with the TV settings but nothing helped. Poor reception, weak signal, caused by coaxial splitter or TV problem?
Years ago in the 90s, I thought HDB forced everyone to migrate to SCV TV point, and the antennas were deactivated or no longer usable. Is this correct?
Somehow my connection is able to receive the Malaysian RTM1 channel, but very noisy and barely watchable. But some people reported that the SCV TV point should not be able to receive RTM1.![]()
SCV point can recv TV1 also but not TV2~ to confirm, if u can tune to 743.25Mhz, u are connected to starhub~
bad reception could due to the type of RF cable or splitter u using~ recommended cable is Belden 1530A RG6, for splitter use starhub or regal 5-1000Mhz type~
