Help... is anybody using Linksys router? Are u able to login to your router interface page?
iggi3z
I had the same issue today, using Linksys EA8100.
My default gateway IP changed from 192.168.1.1 to 192.168.10.1 this morning.
Took me a while to figure out what went wrong. Had to update the new IP address for my IP camera as they were all static to the previous IP and port forwarding and DDNS to finally get it to work.
CSNation
Emeritus Honorary Member
Satki linksys backdoor
Sent from my Toilet Bowl using GAGT
nymous
i don't wanna factory reset cos all my router settings will be gone...
now im asking linksys to downgrade the firmware for me... waiting for their respond... :s22:
u still can change your router ip to 1.1 meh?
i thought the firmware update already force it to become 10.x?
I dont think they factory reset you, more like they send the router excutable script and it change settings automatically... fortunately it has bugs
this is serious security issue
nymous
Linksys always trying to be funny. I tried to login many months ago and failed. Thought it's my own fault. Turned out it's Linksys doing something.
on track for being "microsoft".. u dont own ur router
Intrinion
Moderator
Moderator
well a word of fairness, it’s an auto firmware update went wrong. Rather than say back door.
Intrinion
Moderator
Moderator
There’s an option on the router settings to disable “firmware update “
savoirex
but how come the router login page is dependent on linksys backend svrs? moi is quite puzzled abt tis leh...
RetroActive
Reset seriously, if you already tried but still the same.
Most likely your router gone case need to go service center.
i originally is cannot login to my router always hang after i enter my pw...
but after i unplug those cables from my router except my PC and try login again i csn finally login to my router to change the gateway from 10.1 back to 1.1
but after i plug back all my cable to the router and try login to the router again it still hang...
think i must one by one troubleshoot see is it got any device still stuck at 10.x or whatever that causes it to hang during login... :s22:
RetroActive
it shd be linksys firmware update that was push to update the router firmware as instructed by starhub... those router that was set to auto firmware update will kena...
potatohead
update...
after unplug all those wired connection and internet from the router although can finally login... but then after changing the gateway back to 1.1 and then connect back the cables & internet and try login again it still hang at the login... :s22:
anybody tried?
ok back to to troubleshooting again... :s22:
again, afaik, once your router encounter this login page problem, seems like it is a terminal disease without an easy cure, no matter u hard reset or change gateway settings, upgrade or downgrade firmware, problem will stick. i may be wrong.
certain rom/memory components onboard may need to be re-written (JTAG?), m no hardware/software guy, just read that somewhere.
in short, from now onwards, whenever u want to change any settings on your linksys router, you will need to disconnect it from the modem and do it sans the internet.
other than the above, the router can still be used and functions normally though.
Intrinion
Moderator
Moderator
Let me play around with it tonight. When I turn off my ONT and see if it allows one to login via 192.168.10.1 - theoretically it should since it’s local.
I know there’s an option to link the router to some linksys account - perhaps for some remote router configuration. That may be the “linksys backend svrs” you are talking about.
iMac
Linksys support told me they are fixing something backend and all linksys router currently cannot be accessed... :eek:
You mean Linksys can remotely control your router?
All your email, bank account and classified data can be remotely monitored by them?
Gungalley
Eh so what do I need to do ah? After last night when my router auto restarted, I can't use the 2.4ghz login. Can only use the 5ghz. What's wrong?
RetroActive
are u able to verify that after u kena the firmware update...
then u set your router auto firmware update to disable and then logout and login your router again does the auto firmware update still remain as disable?
just now when troubleshooting i kinda see the disable auto update becomes enable... not sure if rem correctly or i didn't save the setting... will gotta test it out again to cfm...
really waste time troubleshooting sth that shd not have happen in the first place...
savoirex
yes i know. i am puzzled by the login page hanging after keying in the login creds...why does local router login need to verify against linksys backend?
Intrinion
Moderator
Moderator
So to verify if “disable” will auto toggle to “enable” again?
I will do it later when everyone is asleep.
Any router settings will cause it to reset then everyone will shout “Kok Keong bo internet”
Then my ears hot already :s13:
Intrinion
Moderator
Moderator
Sorry, do you mean you can’t use your 2.4ghz ssid?
uncle_josh
to disable the auto update, you need to use the app.
Sent from Because Respect Is A Two-Way Street
using GAGT
