Help please! (Building first pc in my life)
xreflectx1
Hi there, recently I bought all my parts from both lazada and sls and got ready to build them all this morning. Here are my parts that i got
Asrock H81m-HDS mobo
I5-4460
GTX 950 Strix
1TB Blue wd
250gb HGST HDD (reused)
256gb crucial MX100 SSD
8gb Kingston ram single stick
Superflower leadex 550w FM Gold
Finished assembling all my parts and was ready to hit the on button. However, my screen showed nothing except a message 'No video input' Am I doing something wrongly that has caused this issue? This is my first attempt at pc building so I honestly have no idea how to troubleshoot it. Please help me as I am really clueless at the moment.searched online but they told me to check my cables and maybe mobo faulty but I hope its not that case. My cables I followed quite closely to royfrosty's guide but I may have done something wrong idk.
If my hdds and ssd are all empty, without a booting thumb drive will I be expecting any thing once I turn it on or its just empty?thanks!!
Phen8210
Check if you connect monitor to the discrete gpu instead of mb, is the pc running when u on it? any beep? got connect power to gpu?
u shld see asrock logo when u on ur pc.. without hdd or not also will see bios.
xreflectx1
Ah I changed it and connected my hdmi cable to the GPU one instead of mobo and it showed the asrock boot menu. Why is it that when I connect to mobo it doesn't work?
mib500
its always like that...system will recognise gpu as primary if you slot in gpu instead mobo...
djdestiny
Usually the mobo's GPU (The CPU's GPU) won't be enabled if the output is from the PCIe GPU.
Keep in mind that it's so people don't get confused why their performance seems poor.
xreflectx1
Okay thanks! Then like that I can't use my lousy spare monitor already since its vga. Any idea how to enable it then?
And there's only one chassis fan slot on the mobo but I have more than 1 fan. How do I connect the remaining chassis fans to let them run?
zystttt
Either molex to fan head (sls sell $2-3 each), or get a fan controller. Cheap one like NZXT grid+. Or you can use a 3pin y cord from mobo to 2 fan connector tho not recommended.
Gloom me
Use VGA to whatever adapter. Sure have 1 adapter can use. LOL.
As for fans, use splitter, 1 header to 2 headers. Or a PWM splitter. Or molex to 4-pin cable.
Sent from my mobile phone using GAGT
djdestiny
Make sure the DVI port you're getting a adaptor for has these pins
Also good excuse to buy a new monitor. :s13:
You can either buy lots of fan plug splitters or buy molex (the big ass 4 pin plug from psu) to fan plug
xreflectx1
Bros I finally managed to get my vga monitor to display the image after using a vga to hdmi adapter, and my fans are all spinning already! Thanks all for the advice and tips given.
Now one last thing, I have bought a wins 8.1 pro from reddit already. However, after using Windows 7 USB DVD Download Tool to get the win 8.1 activation software into my thumbdrive, after booting it up it kept telling me this "A required CD/DVD drive device driver is missing" or "A media driver your computer needs is missing" error message.
What am i doing wrong? Why cant i install it even though I am 100% sure everything i need is in the thumbdrive already.......
gld998
your image in the thumbdrive is corrupted. pls redownload n use chksun to check whether complete
