Help with HDB networking! Advice needed
class
if i am just using starhub 500mbps, is there any need for tri band. any difference
The plan does not matter. The router recommendation is the same for 500Mbps and 1Gbps plan.
Rather the floor plan, the expectations and budget matter. Please post the floor plan and location of the ONT, and state your budget.
BTW, for all three posted speedtest results of the Netgear Orbi mesh with wireless backhaul results, you will get much better results with Ethernet backhaul. So if you can, by all means use Ethernet backhaul.
