Highest End Semi-Professional Grade Coffee Espresso Machines Mass Order - For Singapore & Malaysia
unwanted
Deluxe Member
If you purchase 2 cases onward, there's a 5 to 10 percent discount.
1 case will be either 20 bags of 250g or 6 bags of 1kg.
testerjp
Thanks, still trying the other blends, will order in bulk next week.
linusz
Bought 8 250g packs for my office last week. Finished in a week.
Favourite blend is Alto Palomar and Meloria.
Meloria is really cheap and good.
All blends very well defined and different from each other.
Any special offer for HWZ mass order?
Looking for long term supplies to my office.
:o
Tried Alto Palmar ground coffee powder. Tasted bland. Does it have to do with the coffee being ground and packaged 1 year ago?
testerjp
I bought it in bean form and grind on demand.
I used abt the same grind setting for my locally roasted coffee got from Nylon/Tiong Hoe.
The crema is rich with the honey notes still there in the aftertaste. Don't have the rancid after taste of oxidised coffee. Meaning the coffee is still good, very good in fact.
Alto Palomar is the most well balanced espresso I had for a long time. It's like the Pinot Noir of coffee. I think it's the closest to the coffee I drank at the Java & Mocca cafe I tried in Oslo. The roast is really just nice. San Luis is another good one, it has a very neat profile but you may not like it if you want something with more pronounce profiles.
If you want a stronger intensity with more bitterness, you need a darker roast. I find Meloria okay. I think it's their smoothest dark roast. My staffs who love those kopi, like the darker roasts.
The yellow label ones from Le Piantagioni are medium dark. If you use Alto Palomar as a benchmark, it's like slightly more bitter and pronounce but the smoothness is still there. My staffs all find this tier pleasant. Forgot is it 100 or 106 blend, reminds me of coffee from Fikafika cafe in Taiwan. The flavours very complex.
The Irridamo taste very bright and more sour, similar to those 3th wave hipster cafes. I personally don't enjoy as much, but a lot of cafes in SG are using coffee with this profile.
So is see what you need lor but better to buy coffee in whole bean form than powder. :o
linusz
interestingly I bought both Alto Palomar and Iridamo as well. was disappointed that both cans of ground coffee are 1 year+
hence i thought the taste was not good as expected.
thank you the sharing on the products. will have to look at a coffee grinder - which one u using?
testerjp
I'm using the BB005 for home, Quamar M80E for office. You doing as espresso or brew? I do only latte or espresso.
If brewing method can consider the chemex way, the flavours should come out good. Buy coffee bean must look at the roast level first, it's like how you want the steak done. The darker the roast the more bitter and less sour. The lighter the roast, the more unique the flavours as you can taste the fruitiness.
Both you bought are the light and super light ones so i guess you want it more robust, maybe pick a darker one. :o
linusz
Latte usually - will try the beans. Need to shop around for budget-wise grinder first.
calbay
You can still make a latte with a light roast, only that it's usually done with a double ristretto for a 6 oz cup or double espresso for a 8oz. Quite a common practise in modern cafes.
linusz
yeah will try - but the freshness of ground coffee wasnt there given it was packaged 12m back.
compuser
Weird, I opened this bag on around 4th of March and forgot about it. Look like the condition is still okay.
Not say my favourite but Yrgalem is pretty close to the ones I had from Nylon with less acidity. The harenna is more interesting to me. San Luis is indeed very neat.
Will try the rest after I'm finished with my current bag.
compuser
Used to pre-grind my coffee bought from local roasters and ready in advance, then realised that there's no crema.
Later read that ground coffee oxidises and loses 60% of its aroma every 15minutes.
Resting for few minutes is equivalent to oxidising for a few days.
https://www.linkedin.com/pulse/importance-grinding-coffee-correctly-justin-metcalf
https://www.noircoffeelab.com/faq/
You should buy whole beans if you are concern, makes a world of difference.
unwanted
Deluxe Member
For the coffee powder range, Iridamo and Alto Palomar are both meant for brew coffee, like Chemex, filter, drip, etc. Not espresso that can be used as a base for latte.
The main difference is in the grinding, which they are done in a coarse setting, far from espresso fine. So it's hardly possible to extract well with it as an espresso. The roasting is also on the lighter side. If you require the intensity, you need to go darker. Given that you are underextracting as an espresso and the coffee is naturally of a gentle profile, we find it is absolutely reasonable that you will think it's "bland".
All packagings are sealed with MAP to keep the oxidation process dormant. However, as the previous poster had mentioned, coffee will oxidise rapidly in powdered form as they break into smaller particles with surface area multiplied by the hundreds/thousands.
For the best result, it can only be from coffee in whole bean form.
unwanted
Deluxe Member
Received some enquiries for the new Bezzera Duo/Matrix double boiler.
After some discussion with FCC, it seems that they had decided not to carry them ATM and placed on KIV.
There are many reasons listed. Technically they think that the machine will be extremely difficult to repair given the tight space and many components. With so many components, the chance of failure is also naturally higher.
The new model definitely has many helpful features to give the user better control but it does not mean that it will produce a better espresso. If the machine will be admitted to their range, the estimated rrp will be near 3.5k onward.
FCC may on the other hand look for new products to be carried in singapore, particularly for offices and fnb.
scorpio88
Hi Bro,
May I know how much you are charging the coffee beans? Any delivery service included?
Any recommendation of coffee beans for morning espresso? Not acidic type.
Thank you.
goldsilvercity
Hi Bro,
Thank you.
n00b here... so the coffee machine style is french press coffee type or pour over coffee type?
unwanted
Deluxe Member
The darker the roast the less acidic.
archcherub
Moderator
Moderator
Anyone tried ordering Laos exotic coffee beans from here?
I was searching for vietnamese coffee beans but found their site. Emailed them to ask, since Laos to Singapore shipping time maybe too long for coffee beans. I think coffee beans will spoil in 4 weeks, right?
so they replied me the shipping from Singapore warehouse. its a singapore firm. :eek:
anyone bought from them can share experience?
