Home Automation Enthusiasts
singcheng
because the wall switch only turn on this "thing" which then i need to use the remote to control which light i wan to turn on, so now i need 2 steps.
1. press the wall switch or using aqara app.
2. select the light on the remote to control this "thing" to toggle between 3 different lights.
Am thinking is there any smarter solution where i can replace this "thing" and control everything from aqara app via the hub..
Either you on "this thing" forever so that you only need Step 2 to turn on lights.
Or, change to a smarter light switch that could work on non-Neutral wire switch and let go of "this thing" and Aqara switches.
Posted from PCWX using SM-N960F
LoneTraveller
ah ok i get it
hmm...
i don't think there is a way then...
since the "thing" is like the master inside the ceiling
the aqara hub/switch only gives supply...
Bro, you do not need to take out this device. If I am not wrong, you are using 1 switch to control multiple lights as was my use case in my old flat. If yes, what u need to do is to manually switch on the switch 1 time and it will light up the first light. Switch off and switch on a second time and it will turn on the 2nd light and so on. If this is still true, then u just need to program your xiaomi switch to switch on, switch off and switch on a certain number of times to turn on on a particular light depending on how it's wired to the "thing"
hq83
yes.
but the problem is
1st time switch on - on light 1
switch off
2nd time switch on - on light 1 & light 2
switch off
3rd time switch on - on light 1 & light 2 & light 3
haha end up all my light will be on. cant on only like light 2. and leave the light 1 to be off.
while reading some old post here.. seem like broadlink rm4 pro might be able to control it ? as this "thing" seem to work on RF
was thinking if Xiaomi Aqara Two-way Control Module or another lighting wall switch but then hidden in the ceiling and control with the app might work.. but seem like dont see anyone doing it..
xenocide
yes.
but the problem is
switch off
switch off
the thing about RM Pro is that, the learning of RF devices can be a hit or miss. if the remote u have can be learned, then all will be good and can be controlled via the Broadlink app (maybe some automation as well)
you will need to know the frequency of the remote you have.
RM supports 433 and/or 313 ( i forgot its both or either)
s_m_hafeez@hotmail.com
Hi, anyone got aqara hub that works with sg server and mi home. I noticed recently the wall switches is added to mi home in singapore server but need aqara hub. Was wondering whether it supports wireless switch mode to control yeelights.
xenocide
if you can find the device in SG server, chances it will work is pretty high.
as for the Hub, make sure you double triple confirm with seller its SG compatible. I bought 1 from shopee. They told me its SG compatible but when i try to connect using SG server, the Hub will never get paired. Once i switch to mainland China, the hub works good. Luckily the devices like my aqara switches are "universal" and not region specific. I just have to live with the slower response time of china server.
side note: things like the mi fan, mi cam alike devices, which does not requires a hub, also depends on device region. make sure the device is SG compatible.
i had a DaFang cam and MiFan 2S, these 2 are not SG compatible.
so in the end i have 1 MiHome app with 2 server of devices.
Need to switch between servers to control them. (in the end i have MiHome China on my main phone and MiHome SG on my secondary phone)
if you using Android, can make use of Dual Apps or Dual Space to have duplicate MiHome app. (i did this on my POCO X3)
dereklim1985
I now thinking about my new house coming soon, so I decided to change all lights, blinds and electronics to integrate with Google home/assistance, what is the best brand or model that I should use? like example my light switch, the power plug, blinds.
xenocide
for google, can try this ecosystem by Tuya
it has a wide range of switches and hubs and devices.
rAcEr
Anyone can advise the key differences between sensibo sky and air + room sensor?
