Honda Fit/Jazz Part 2
HondaJG
Found Lots of Honda car gearbox got issues, mostly are civics.
High chance is gb issue.
I got the same issue before in fd, not sure they are used same gearbox or not.
my is Jazz 1.3 (2nd Gen) with current mileage of 192000.
most advises given in the forum and AD SA are pointing to the same thing - time to change the gearbox. :(
Sainterly
If from P to Any. u will feel a big knock. it time to repair/replace gearbox.
Which is better to repair unless replace new and recon.
normally clutch plate/flywheel, conventer. etc. after repair can last u another 150-200k km.
HondaJG
understood is replaced rather than repaired, due to wear & tear over high mileage.
CCCustom
The biggest problem is not the gearbox but the gearbox oil. Whatever the mileage it is specced for, replace it in half the time. E.g. HMMF for CVT is specced for 40k ... you use it more than 20k you already start to notice problems.
Sainterly
Anyone know what the model of fit hybrid?
I know it should not be GK.
XxlwAteRzlxX
how many years left? which year?
brand new , full accessories. car will reach next year tho
or should i get from another PI at 69k full accessories as well but can collect immediately ?
personally i am in no rush
converse2010
Anyone else booking the Jazz RS by KM over this coming weekend at Expo?
HondaJG
already booked mine last month & will be coming in next month..
pls share your outcome on your booking this weekend. Good Luck on the dealing!
**I will even more heart pain if you get better deal than mine.. But still like to know. :s31:
HondaJG
it seems like KM is prepared to "lay-long" Jazz 1.3 for this weekend. it is going dirt cheap now.. :s31:
HondaJG
Booked/bought already don't look back le.
is about long life learning la..
maybe there are newer freebies the SE will throw in which I do not know?
cos I still got one more shot on the day for down payment.. :s21:
AL5509
Good luck!!
Nanonited
How much is dirt cheap?
Saw it is 68k for the basic model.
Must be at least 50k then can consider...
