How to build a roaming Wi-Fi network by using powerline?
i-Movies
I have Fibre --> Apple AirPort TimeCapsule (main base station, SSID1-2.4Ghz and SSID1-5Ghz used in living room) --> Aztech power line --> Aztech power line with Wi-Fi (SSID2-2.4Ghz used in farther away rooms)
House does not have built-in ethernet cables thru each room, is it still possible to build a seamless Wi-Fi roaming network with above combination? I am looking for something like SSID1-5Ghz used by computers for high speed, and SSID1-2.4Ghz used by mobile devices thru all the rooms for convenience.
I read some articles, all talked about setting up roaming Wi-Fi by connecting different base stations via cable, will that work for powerline? How to setup power line to bridge to main base station?
Thanks in advance
renfred89
Wifi roaming is defined as a protocol which operates in IEEE 802.11r. With that protocol in mind, it is only available for enterprise access points.
In your context, it is not possible to deploy the above protocol in powerline. But, you can make the SSIDs the same so that your wireless clients can automatically search and connect. You might need to adjust the signal strength so that you avoid any overlapping in coverage..
i-Movies
Is it? I saw many mentioned Apple airport TC or Extreme + airport express can build a seamless roaming wi-fi network, but I don't know how they defined 'seamless', my understanding of 'seamless' is that intent connectivity won't be lost when devices switch from one router to another...
I was thinking of using same SSID, it should work but I believe network will be broken since device needs to disconnect from one router, and then reconnect to another.
renfred89
no matter which roaming protocol they use, there will still be a momentarily lost of connection. the question now is, how long is the disconnection?
Here is an article to help you: https://support.apple.com/en-sg/HT204616
note that apple uses the roaming in quotation, that means its not a true roaming as per IEEE 802.11r protocol. you will expect a significant delay in apple's "roaming" set up when your devices drop one access point and attempt to connect to another.
in the near future, singtel might roll out the wifi-mesh technology which offers seamless roaming.
Here is an article on wifi-mesh:
https://en.wikipedia.org/wiki/Wireless_mesh_network
i-Movies
yes i am aware of apple's article, and few other articles that all talked about setting up a roaming wi-fi with airport family, some especially mentioned 'seamless' while some didn't, and that's where my question came from, what if i connect these base stations by power line instead of suggested cables...
anyway i just tried myself, same SSID same channel on power line adaptor side, didn't really feel interruption when moving device among rooms...i did see signal strength changed from strong to weak to strong (change to another point) automatically. so i am OK with this type of 'seamless'.
one thing i don't like, that's also expected, speed on that common SSID dropped around 40-50%, didn't really impact the usage for mobile devices though.
i-Movies
Question: Does same SSID make auto-switching more sensitive / seamless? Or it makes no difference comparing with switching between different SSIDs since it needs to disconnect and reconnect anyway.
