MrSinkie95
- May 20, 2015
Everyday once afternoon le face and hair oil starts to surface liao. specs jin oily. face also. how to control ah?
you need these oil one. cant prevent it completelyno products to stop oil generation?
wa i didnt know moisturiser can reduce oil productionmake sure u drink ample amount of water and apply moisturizer. Ur face is producing oil to make up for de moisture loss
make sure u drink ample of water and apple moisturizer. Ur face is producing oil to make up for de moisture loss
this is true, the more u wash ur face, the more oil ur face will produce to 'moisturize' it.
but if dont wash in the first place, face will be super oilythis is true, the more u wash ur face, the more oil ur face will produce to 'moisturize' it.
U wan e home made version or go expensive facial one
