Did you select AX3 Pro for the Model?
Your screenshot is showing Model:Huawei AX3 / Color:White.
AI Life is Smart Home on iOS, HiLink is the old app and doesn't support newer devices incl some WiFI 5. Most likely it'll be updated to support the new device.I wonder if these huawei router apps in english will work with china routers:
Huawei HiLink (Mobile WiFi)
https://play.google.com/store/apps/details?id=com.huawei.mw&hl=en
HUAWEI AI Life
https://play.google.com/store/apps/details?id=com.huaweioverseas.smarthome&hl=en
If they do then it'll be easier for me to configure the china AX3
Teardown and preliminary review on 路由器评测, focused on range and high attenuation conditions, heat
https://www.acwifi.net/9665.html
Questionable MU-MIMO (WiFi 6) support on Xiaomi AX3600
https://www.acwifi.net/9512.html
Received my white Ax3, not able to connect to M1 broadband. If I connect to my existing Asus router, it is working fine. Anyone managed to connect, please help to advise. Many thanks.
HUAWEI AI Life
If they do then it'll be easier for me to configure the china AX3. even better if there's some intl rom we can flash to.
