Huawei AX3 Pro - Anyone bought and tried?
amazingone
For those who want local warranty and international FW (also those Singtel ONT users who need and SingTel VLAN), the local version AX3 Quad Core version is worth considering.
https://shopee.sg/product/181050132/...1-1616507360.9
S$98 before voucher/discount, from official Huawei Shopee Store
The difference between the AX3 Pro and AX3 Quad is just the TX power being weaker on the Quad right?
esca
lazy999
Hii everyone, i currently on m1 500mbps plan and intend to get the huawei ax3pro. Do i have to set anything or its just basically plug and play?
Sorry if this qn is being asked before.
magix
Because there is a change of router you need to call M1 (via phone automation or speak to Support engineer) to reset your fiber profile.
Call 1627
Select 2 (BB svc)
Select 2 (Tech Assistant)
Select 5 (unable to connect to internet)
Select 1 (Network reset)
Enter your M1 account number (need your M1 bill)
Enter a mobile number (SMS u once it done)
Now try connect your Router and u new router should get a internet connection.
lazy999
Call 1627
Select 2 (BB svc)
Thanks for your advise.
Will try it out.
rainforest
Hi, I am using ax3 pro as ap, after config I do get intermittent wifi, when I try to enter the 192.168.3.1 it prompt exceeded the time limit. Any help? Thanks.
