I ish expert in Car Engine Mechanics, AMA!!
How engine work?
Hard to put into words.....very long story. Simple lay man terms. Air and fuel enter combustion chamber, spark plug ignite to cause mixture to explode. Pushes piston down to turn the crankshaft. Then the exhaust exists the combustion chamber. Typical for a 4 stroke engine.
wahkao3
Whats the difference between different engine oil and do they play a difference?
purpleflock
that's for petrol engine only.
runeruin
whats the effect of injector nozzle widening and whats the cause of it?
Can I put cooking oil instead of engine oil? What will happen?
Sent from Samsung SM-N910G using GAGT
Can but engine spoil lor.... Cause cooking oil cannot provide the lubrication required by an engine. Engine oil needs to cool the engine and lubricate the moving parts. It also need to keep the engine clean. Cooking oil cannot do that.
However, it is possible to make used cooking oil into engine oil.
