XxInNOutxX
- Oct 19, 2007
Any advice on Trenco and eco+ vinyl brands? Are they good brands? If not is it worth it to pay more for better?
hi hi, you can try if the unevenness do not come from the bare flooring but the parquet, remove those uneven one use self leveling cement to even the area before overlay vinylhi.. I have an uneven parquet flooring in my bedroom with built in carpentry. am I still able to level the existing parquet flooring and overlay the vinyl without dismantling the exiting built in carpentry? thank you.
Any of you have installed SPC flooring on balcony in which some portion will be exposed to rain?
You don't understand the meaning of overlay.Hi Jyeoh,
My parents house is a 4A type HDB.
Due to the age of the house (1984) till now, the tiles started to 'pop'.
Was thinking of doing vinyl overlay, not vinyl flooring.
Got lots of furnitures. Need to hack away the existing tiles and re-cement.
Maybe waterproof one layer then do vinyl overlay.
It's quite a nightmare actually. Able to advise pls?
have you condsidered sanding and re-varnishing the parquet as another option? IMO parquet has a much nicer foot feel than vinyl or tiles, albeit it has its downsides as well. and sanding and re-varnishing the existing parquet should be the cheapest of the 3 optionsNeed advice. I want to do away with current parquet flooring of the bedrooms.
ID advice to remove all parquet which I think it's ok but considering to replace with vinyl or tiles. He told me need to screed and vinyl will be more expensive than tiles. I always have the impression that vinyl will be cheaper?
Hi..I want to remove parquet cos it's difficult to maintain..have you condsidered sanding and re-varnishing the parquet as another option? IMO parquet has a much nicer foot feel than vinyl or tiles, albeit it has its downsides as well. and sanding and re-varnishing the existing parquet should be the cheapest of the 3 options
simple overlaying of vinyl is cheaper than tiling, but combine screeding and vinyl installation, then the cost becomes comparable.
