If you're thinking of buying a Secretlab chair... do NOT. Winter will come.
hyperfuse
Yea I spend quite abit for my royale napa leather chairs and I can see that it surely Will last. I have also now change to an aeron after just using my royale chair for less than a week not because they are not comfortable, but because its hot if u don't use aircon.
If comfort wise, maybe the gaming chair is abit better since its smooth and lie backwards. The aeron is definitely not 1.5k worth of comfort, but probably pay for branding and for the ergonomic sitting posture.
saintx3
Is Titan really big compared to omega? I bought omega and I feel the seating area quite cramp
chaoprokia
Embody would be better
mangopapaya
I gotten myself a Kraken fabric gaming chair from Apol. I chose Kraken mainly for its lumbar pillow where it can sort of like 'adjust' upwards and it still stay there nicely. so far so good for me, it helps cushion my back really well. Thinking of getting one more for my dad as well. They currently have a GSS sale going on. Anyone tested other chairs to give opinions or should I just stick to APOL?
localITguy
i have the Nitro Concepts S300, value for money 300$ only. may want to take a look. if u are looking to save a bit
hyperfuse
Just take a look at carousel..
Search for secretlab, apol etc
Lotsa people selling..Guess they fell into the hype of gaming chairs and after using them...realise its not a good fit for singapore climate so selling it away.
elmariachi
I've had my Secretlab Softweave for slightly above 1.5 years now and it's held up very well. Almost the same as when I first got it. Their P.U chairs is the main issue and not sure how their new ones will hold up with their supposed new material as it's not even in the market long enough to conclude.
iicecube
I wonder got any complain on their secretLab softweave fabric chair?
Cause I also wanna buy new chair too.
What the sitting comfort for the omega fabric series? For slim people
elmariachi
So far none on mine.
Very comfortable though Softweave without aircon does feel warm after some time due to the nature of the material so just take note.
Viper0402
Real Brazil Cow Leather premium chair, bought cheaply during Lazada 6/6 Sale at $359.90 after $70 worth of vouchers.
FINALLY no more PEELING problems & headaches.
Very comfortable and high quality build.
Forget about what Secretlab or OSIM gaming chairs, etc.
hyperfuse
Cant even adjust arm rest height.
Get a real chair like a herman miller.
UptheToon
Their marketing really so power can psycho people get their "gaming chair". I hope people don't fall into this and actually get a proper ergonomic chair which can be bought for half the price which has the real purpose of protecting your back and comfort.
kenzi87
If can see the spending how much go into marketing compared to R and D?
说好不打脸的
Does any bro came across the name Noblechairs or own it? I had tried out once in a store at SLS. But not sure is it worth the value and how good is the durability.
localITguy
i can tell. i have a nitro Concepts S300 (good quality and solid seat) which also owns the noblechair branding, (same factory)
as i have not owned a noble chair. i cannot comment, but i would expect the quality to be good.
i suggest you to go for a Nitro Concepts S300 as it's a cheaper option. ( u save alot of money
说好不打脸的
Thanks bro, i will go down to have a look when i am free. I did a search just now, the price is $289, wow.. near 2X cheaper than Secretlab Omega?...:oops:
hyperfuse
Dont buy gaming chairs~
I last time ignore people's comment here and thought that it will be ok...
buy already then regret. Gets hot so easily and nothing ergonomic about it.
