Incorrect Information: Tales of Arise Review: A flashy and enjoyable JRPG that's gloriously rewarding to play
FroztSpectre
In this article, the author mentioned the following statements
"For one, there's no multiplayer anymore, and depending on how you look at it, it can be either a boon or a bane, though for me it was the former since I'm generally a solo player. According to explanations from the developers, they did away with the multiplayer combat aspect in favour of streamlining character combos, and this change presents itself in the form of the Boost Strike ability."
Additionally, in the Verdict, the following statement was made
The Bad
  • You can only use Alphen in combat
  • Read Point 1
Based on the statements made, i presume that when the author mentioned "multi-player", he actually meant swapping/controlling of multiple characters in the game.
This is wrong, as Tales of Arise actually does allow swapping and controlling other characters other than Alphen.
In the PC version, holding Alt+1,2,3,4 would allow you to swap characters to control, and not just using them for the boost strike. This can be done using a controller as well. Additionally, you could amend the "Party Leader" in combat such that you'll always start any fights with that specific character.
This method of playing is basically required if the player decides to play on a Manual combat setting, instead of Semi-Auto or Auto.
"Manual is a Battle Option that gives you full control of your current playable character during battle scenarios. This allows you to move around and use your abilities freely without set strategies activating while in battle.
Manual provides you with the most freedom and control out of all Battle Options. This prevents automated commands from breaking your combos, allowing you to pick abilities and attacks on the fly.
" -game8
To switch Battle Options, go to Edit Party in the game menu. You can pick any of the 3 options on the screen (Auto, Semi-Auto, Manual), along with changing battle members in your party.
show
Credits: game8
Using other characters in combat:
show
show
Credits: game8
