- Jul 5, 2001
No rah won’t happen for the screen. Likely island again.Next model shld be the remove the island and leave only the hole there
A better chip
Change position of action button
Or add one more button
Change composition of titanium
Reduce weight of all models by 1 gram
Island looks uglyNo rah won’t happen for the screen. Likely island again.
graphene heat sink
Sony IMX 903 sensor
48MP wide angle camera
I don’t mind the island. The problem with 15 pro is the heat. Else I’ll still be using itIsland looks ugly
Most probably white or transparent island for more screen real estate
Then they will say it is a new feature cos screen real estate increased
Lol
Mine is iPhone 15I don’t mind the island. The problem with 15 pro is the heat. Else I’ll still be using it
I was in Taiwan when I used the action button for camera. After sometime I noticed my pocket is uncomfortable sensation. That’s where I realised my camera mode didn’t properly locked. So hot that when when I held it with the case still unbearable.Mine is iPhone 15
So far so good it doesn’t get hot
Your iPhone 15 pro is hot cos of location services?
Send analytics data to Apple?
Background refresh of apps
I normally disable all 3
Location services - I set to while using only
Maybe 15 pro max dissipates heat betterSeems like all the heat from the smaller 15 pro. I have not encounter any heat issue on my 15 pro max.
Just change the action button to mute switch. For me personally, I don’t like duplicate of action for launching of camera app - since the Lock Screen bottom right already have camera icon, I just hold it for 1sec or swipe left can liao.I was in Taiwan when I used the action button for camera. After sometime I noticed my pocket is uncomfortable sensation. That’s where I realised my camera mode didn’t properly locked. So hot that when when I held it with the case still unbearable.
Too late bro! Already sold. IT don’t discount the problem with heating issue that’s why iPhone 16 will use better heat sinkJust change the action button to mute switch. For me personally, I don’t like duplicate of action for launching of camera app - since the Lock Screen bottom right already have camera icon, I just hold it for 1sec or swipe left can liao.
Action button should be reserved for what it’s used to be, imo - mute toggle switch.
Really shouldn’t get the heat issue if you toggle all the right things bro.
According to previous iPhone roadmap leak for Pro models:Next model shld be the remove the island and leave only the hole there
If this roadmap comes to fruition, then iPhone 19 or 20 could look just like any other android phone, unless iPhone got more buttons than android.According to previous iPhone roadmap leak for Pro models:
Source : https://bgr.com/tech/huge-apple-leak-shows-iphone-plans-through-2027/
- 2023: Pill shape
- 2024: Pill shape
- 2025: Under panel Face ID + hole
- 2026: Under panel Face ID: + hole
- 2027: Under panel face ID + under panel camera
16 Pro will adopt Micro/Mini LED.According to previous iPhone roadmap leak for Pro models:
- 2023: Pill shape
- 2024: Pill shape
