Any update on Singtel e-sim compatibility and when can use? thanks
Review set?
How come Apple never give Kim Huat a set to review.
Even when Singtel roll out e-sim... I might be hesitant to switch from the physical sim... because if we roam to a country without e-sim compatibility... we are not reachable in the local number....
Saw the gold colour iPhone. Love it.. I’m so getting gold for my iPhone Xs and Xs Max. For Xr then get black.
Where did you get this information? Doesn't sound to me how eSIM works.
Isn't eSIM supposed to work like normal SIM, the difference is eSIM is embedded within the phone, where else SIM is separated from phone physically. Functional wise, to switch Telco (i.e. M1 to Starhub), eSIM will switch M1 profile "softwarely" over the air to Starhub profile after you done signing the "paper works". As for SIM, we switch physically the SIM cards.
When you roam, both eSIM and SIM supposed to behave the same since there is no change in profile. Roaming is part of the profile provided by the Telcos.
Probably yes. Since you are basically riding on SingTel to provide you the Digi signals.I think this is what he means.
For e.g. you’re on SingTel eSIM locally.
Assuming SingTel ties with Digi in Malaysia. Digi doesn’t support eSIM. So when you go into Malaysia, will you be having any connection? Cause Digi doesn’t support eSIM.
