kF94 or Surgical mask?
WussRedXLi
Anhui Ruierxin (shopee EZlifeSG) vs Anhui Ruierxin (i bought it from qoo10 EZlifeSG, but not mixshop)​
Don't know why the result is like that. Probably same as last time in which mixshop's stock measured bad 1 time.
Ender
anyone can recommend a N95 mask to block garbage or shiiit smells ?
Not for covid protection wan. just to block smells.
Thanks.
Think09
The F972 is the KOY KF94 lah. I posted that before coz i wanted to buy last time, it's a decent mask, seen the reviews before. That time i remember the other seller was selling 14.90 normal price (not time sale). So after coupon, supposedly is $11.90 shipped.
So i believe Mezzang shd be similar (from its normal priced listing), or maybe $1 lower.
Just check the price. is $14.98. Wonder worth to buy ? As the white is in already.
WussRedXLi
Ender
Same price as the F912.
If you still have not found your favourite mask that fits you best in terms of leak (if not using surgical tape), earloop, comfort, price, then can try this new one.
13.49, then deduct $3 30% coupon and also deduct the shipping fee with the shipping coupon.
https://www.qoo10.sg/gmkt.inc/Goods/Goods.aspx?goodscode=683342830
The pricing of F912 is my upper limit for buying mask, not willing to spent more. Will try the F972 on my next buy when the 30% coupon capped at $5 is release.
kw442
Found this thread, read several pages and ordered the F912 this morning.
Paid S$(13.9+2.99-5.99-1)=S$9.9.
Thanks for the tips on multiple accounts to spin the wheel to get coupons and quantity adjustment to apply both coupons.
Squaredot
bro, next time order F912 at this listing is better, $13.49...checkout total will be $0.41 cheaper :o
https://qoo.tn/BjiiwX/Q130011338
Shawny88
Ender
Bro, which type do you recommend? Yoo many types in the qoo10 shop till I blur liao. TIA!
My opinion, just PPE filtration criteria, any of MEzzang's KF94 certified mask is can buy one. The other consideration which differ from person person is the size fitting, and for some like me price.
Many like to use F731 as the reference coz this was what many epople would have bought one point in their time, and from there we will rate the model bigger or smaller. My experience is F808/F801 > F912 > F731>F919(OOS).. So far we found F919 suit most petite ladies. My daughter and wife prefer this.. My wife now uses the F731 while saving the remaing F919 for my daugther.
Using the lanyard mask adjuster, my daugther can ewear the F731 with decent coverage and sealing.
Squaredot
@Ender
May I ask how does lanyard mask adjuster look like? She uses mask stopper for F731 and Vi-fence to close the gap at her chin. Only F919 is perfect fit for her but no longer available for sale liao. Hope to find a fit same as F919 :o
zepanda
BT Korea white, F740 Dream mask, F506 (A3), Wes Care surgical, Jangaran KF94 by Charmzone
thanks for the vid, so this shows how well the mask filters particles <0.5um and <2.5um? this means that f740 and f506 doesn't filter <0.5um well since the readings stay at 2k+?
for the charmzone one, why did it hover around 300+ until the detector was shifted? is it because it wasn't sealed well at first?
Read HWZ Forum Rules!
Ender
@Ender
The lanyard adjuster link below. The next best fit for my daughter with lanyard is actually the BT white mask. But that one got expensive when they put all their items on time sales, i.e. cannot use coupons. Can try the BT black premium coz it the same size and around the same price and with premium packaging. But I suspect the new f972 might a better fit for her.
https://shopee.sg/product/250741993/9860101315?smtt=0.1287552-1642133841.9
WussRedXLi
V difficult to say...... just have to try the various KF94s until you find one that suits you.
The models F731, F912, F929, F527 are all decent you wont go terribly wrong. Personally F808 i find the front panel a wee bit close ot the mouth but others like my wife and some folks here are very happy with it.......after all it's damn cheap (cheapest KF94) + the innerply quality smoothness is above avg. I believe the F972 KOY also would be fine from the reviews i read from other listings (KOY KF94).
Then F801 actually the inner ply is very smooth, only issue is that it sits rather close to the lips, so that one confirm would touch lips one.
Some want a higher quality mask with higher quality outer and inner fabric and so go for other brands, which is fine too.
Some want it cheap, or even try chinese stuff (air for 3 days, all smell gone) at less than $5 for 50pcs, coz they use a high number daily, only trick is to find something that is decent in filtration.
WussRedXLi
Sort of, just look at the 0.5 microns number, it's a cheap meter, nothing fancy or accurate. You just need a ballpark number to show before/after and also to compare bt masks......which it can easily do esp if the challenge aerosol levels are decently high (that is why sometimes i use a pc of smouldering tissue to get it from say 1.5k -> 9k.
In fact tissue paper or wood smoke is predominantly 0.1 microns plus minus. Cigarette is 0.2 0.3 microns median for eg.
Good catch. I think so......prob v minor leak at the bottom then, coz i stuck and closed 50% of my air purifier outlet with scotch tape so that the base of my meter rests on it, and also 30% of the the bottom of my meter is with scotch tape also. I think a wee small portion didn't sit well then, so i just shifted it and it went down.
Coz i know this Jangaran/charmzone KF94 will measure well coz before the video i already tested it......and someone else also sent me charmzone stuff before as well.
this shows how sensitive a mask is with leaks, in relation to my meter's readings (which is rather sensitive, just not sensitive/accurate enough for those what 99.xx % conclusion coz anyway my challenge aerosol is ont standardised )
This also gives an idea to us how important the fit of the mask is, and how important it is to use a good surgical tape (ie 3M micropore, v sticky.....tho i guess many hate this).
The mask to be tested would sit between the AP outlet and meter's bottom inlet hole. The meter's both sides are taped up, leaving only a small hole at the top for it to exhaust. the laser particle counter module is the silver one, with the black coloured sampling inlet visible. (around 90 deg perpendicular to the incoming filtered air)
