bert64
M1 download speed has been dropping to 50Mbps at night. Does this mean I need to search for a new ISP? I guess upgrading to 1Gbps will not help?
Sounds like a fault, either with your own equipment or with the line. I would investigate the cause and try to remedy it.
Where exactly are you downloading from, how are you testing it, and what speed do you get during the day?
ruffruff
Hi bros & sises,
I recently move apartment, but still within Yishun, and had relocated my M1 Fibre 1Gbps service along.
My network setup:
M1 Huawei white box to Asus AC86U (main router)
AC86U connects to AC88U (wired) and a second AC86U to form AI Mesh.
In my old apartment, my gaming PC was connected to my main router directly via LAN cable, the speedtest usually hover between 800-900 mbps. Speed was good and I had no issue with gaming or video calls.
In my new apartment now, the same setup, but speedtest through my gaming PC is 300 - 400 mbps. I tried connecting directly to the main router LAN port via LAN cable (previous was through a switch) or tried using a laptop with LAN connection to another LAN port on the main router but the test results are the same.
M1 had sent their technician over and replace the Huawei white box, in their test, they said that issue is with my Asus router and speed test through the huawei box directly gives a 800+ mbps results. I tried switching the 2 AC86U over but the results are identical. Haven't tried to switch the AC88U over as main router but that is connected to my NAS, so a bit reluctant to try that.
Does anyone know what else can I try to locate the issue or improve my speed? :unsure:
Thanks in advance.
eauyong
Hi bros & sises,
My network setup:
Thanks in advance.
Try different Lan patch cables.
bert64
Hi bros & sises,
My network setup:
Thanks in advance.
Check the router settings... Aggressive QoS settings or large numbers of rules can overload the router. Most of these devices are specced to just barely reach 1gbps under ideal circumstances, as soon as you add any extra complexity you'll drag the performance down.
ruffruff
Yup, tried that with different cat 5e and cat 6 cables. I rule out cable issues (within the wall) by testing using direct cable connection to the router.
Yes, I found that the adaptive QOS and AI Protection does affect the speed, but these were the exact same settings that I had in my previous location and speed was at 800+ mbps then. If I turn off all additional rules or protection settings, the speed back then was 900+ mbps.
However, in my current location, I am getting only half the usual speed. With all settings and protection off, it climbs to 600+ mbps only. :(
Elijahonli
I occasionally noticing the same behaviour
Factory reset the Asus router and try again.
Have you upgraded the Asus router FW recently? RT-AC86U is an excellent AC router but I would not be surprised that Asus FW upgrade quality issue may cause your issue.
Are you using Ethernet backhaul or Wireless backhaul or mixed?
Switch off the RT-AC88U and second RT-AC86U to check iif AImesh is causing the issue or not, especially the RT-AC88U may have bad FW version and cause the Ethernet backhaul to become wireless backhaul.
One of the brother here recommend the following (I do not need to do this with my single RT-AX82U though). There are multiple reports of Asus FW upgrade issues in this forum: Asus Zenwifi XT8, RT-AX88U and RT-AX92U.
If you have no issue before firmware upgrade, then after firmware upgrade you need to do a reset, this is asus style, no choice, if not, then strange problem may come out. Usual method - power up, wait 2 mins, then hold reset button for 10 secs until power led blinks, 2 mins later then reconfigure again (usual ssid + login) and then reset mesh node + setup mesh again.
elanwy
Using wired connection with Asus router RT-AC1200G+. Tested with Speedtest Single connection, right now (5pm) it is only 65Mbps. It goes back up to 500Mbps occasionally but it's bad half the time.
In your case, if majority of the the time it is okay but occasionally you get low speed, it could be M1 SpeedTest server issue, try Viewquest test server to see if the issues go away. But if you test different servers and the issues are still there, it could be really M1 problem. It is said M1 has worse contention ratio (more people sharng the back end equipment) compared to SingTel and Starhub, which means occasionally M1 may have lower guaranteed local speed compared to the other two ISPs.
If you encounter the issue very often, then most likely it is the equipment issue, contact M1 to change the ONT to see if problem goes away. If M1 tests the ONT and it is okay, then it is most likely your router stability issue. RT-1200G+ is probably the lowest end router from Asus so you may want to consider changing to a better router as well.
elanwy
Thanks for the advice! I'll go into the router settings and poke around first.
ruffruff
yup, tried that several times. I just bought a new AX88U router from M1 today (their price is cheaper then challenger/lazada/shoppe), but the results are the same after all is setup. But during the process, I found something as well:
1) The original firmware of AX88U, I was able to hit 800-900mbps down after all the router configuration (not yet added the aimesh nodes). Once I upgrade the firmware to the latest, immediately speed goes down to 600+mbps.
2) After adding the aimesh nodes on the new firmware, speed further drops to 400-500 mbps.
I tried downgrading the firmware to the earlier versions, but speed doesn't cross over 600mbps anymore. Seems likely to be a firmware issue then .. pissed ...
You can check out the RT-AX88U thread. There are multiple reports of Firmware upgrade issues reported. Same for the Asus Zenwfi XT8.
You may want to try factory reset or contact Asus for help.
Actually RT-AX86U seems to be better than RT-AX88U based on the feedbacks in this forum and there was a 618 promotion from Courts at S$312 for the Gundam special edition. But that promotion is no more.
AlvinDj
May I seek for the kind guru's advices..
M1 is now offering me either a free Asus RT-AX55U or TP-Link Archer AX73 AX5400
On paper, it definitely seems like the TP-Link's AX73 AX5400 is a much better choice but I would like to affirmation on it before making the decision..
If anyone can share some thoughts on the comparison between these two?
Cheers!
Technically of course TP-Link Archer AX73 is better than Asus RT-AX55. It also usually costs higher. So if you only plan to get a single router, then AX73 is probably the way to go.
However, Asus usually gets better long term support, and RT-AX55 can be a very good AIMesh node. If you plan to use mesh, then I will actually suggest getting the RT-AX55.
AlvinDj
Thank you for your kind inputs!!!
Yea, I felt the same on AX73 being the better choice but just alittle worried on it's reliability as I have never tried nor used any TP-Link routers before lol
Can't really find much infos or posts shared on this particular model at all in this forum..
Yes I only plan to use it as a single router, so for now, I guess AX73 it is then!
magix
I think reliability is there for tp-link. Just don’t expect firmware support of 2 or 3 years as compare to Asus (so far some old model are still getting Adhoc security update).
TP-LINK firmware update very little not sure if really their product no security issue.
AlvinDj
I also hope the setting up of TP-Link isn't complicated to do..
The only few positive things for AX55 over the AX73, one of them would be the quad-core processor vs only triple core on the AX73
Wondering if it would hinder the loads I may put on the AX73 as compared to AX55's quad-core?
TP-Link product is easy to set up. It lacks the feature and long term support of the Asus routers.
BCM6755 (quad core ARM Cortex A7 1.5GHz, mainly for AX1500/AX1800 router) is actually a bit lower end than the BCM6750 CPU (tri-core Arm Cortex A7 1.5GHz, most often used for AX3000 and AX5400 router). They are basically the same in terms of CPU power, BCM6755 might be slightly more powerful because of the extra core but practically speaking they are the same.
BCM6750 is used in Asus RT-AX58U/82U as well as Asus Zenwifi XT8. I am using the RT-AX82U, the CPU is fine to me. Of course you do not want to enable QoS as the CPU is too weak for that. On the other end, even the BCM4098 CPU used in RT-AX86U is not really good for QoS at 1Gbps.
Problems with RT-AX55 is actually the 256MB RAM compared to the 512MB RAM in RT-AX56U (same CPU), if you have a lot of clients. TP-Link AX73 uses BCM6750 and at least it has 512MB RAM, the same CPU and RAM as Asus RT-AX58U and RT-AX82U. You can consider it as a low cost alternative to RT-AX82U.
TP-Link HW/FW are pretty stable. I have used multiple TP-Link product like TP-Link Deco M4, RE350 and RE305. Problem is long term support where Asus is the best among the consumer router vendors. Asus FW also has more features which may be useful for power users (eg: built-in SSH access, more wireless tuning). But a lot of users probably not really using the features.
