It's only your mindset but you're still paying 29.90/mo for your broadband.
Indeed. Without the broadband it still costs me $10+ a month for the landline.
2.5G LAN port is useful if you have 2.5G capable NAS or PC (adapters are not expensive but 2.5G switch is still not that cheap).
As for FW, different AImesh Asus router will have different FW due to different CPU and other HW components used. I tend to believe RT-AX88U FW issues (especially for AImesh) is related to the fact it is using BCM49408, a less common model compared to the BCM4908 used by RT-AX86U and GT-AX11000 (and many other high end Wifi 6 routers). RT-AX88U is one of the first WiFi 6 router in the world so the solution may be less mature as well compared to others. But it is still not a bad router though.
If you go to different review sites you will see that RT-AX86U is deemed as one of the best AX routers out there.
Nvm, just saw the Singtel plan for the RT-AX86U, $64.90/ month….
I’m actually a MAC user, will the RT-AX88U works for me?
Note: There is a shop selling the RT-AX86U @ $489.99, is the price reasonable?
M1 got ROG AX6000 at $13per month same as AX88U... which is better option?
Price wise maybe ROG AX6000 is newer hence more expensive.. I wonder specification wise is it better than AX88U?Hmm, is this true?
Edit: it is indeed true. Both are at S$13 per month. Then for sure GT-AX6000 is much better deal than RT-AX88U.
https://www.m1.com.sg/home-broadband/devices/asus-rog-rapture-gt-ax6000https://www.m1.com.sg/home-broadband/devices/asus-rt-ax88u-wireless-router
Asus ROG GT-AX6000 retail price is at S$699 whereas RT-AX88U is only at S$499.
https://www.challenger.sg/biz-solut...-gaming-router0--0195553394567?h=MSwxLDAqNjk5https://www.challenger.sg/biz-solut...rt-wifi-router0--0192876032817?h=MSwxLDAqNDk5
I just read it up online, seems like its using WIFI 6 instead of WIFI 6E. Would that be any concern?Price wise maybe ROG AX6000 is newer hence more expensive.. I wonder specification wise is it better than AX88U?
Yes the spec is also quite a bit better because of faster CPU and 2.5G LAN port.Price wise maybe ROG AX6000 is newer hence more expensive.. I wonder specification wise is it better than AX88U?
What do you mean? Both GT-AX6000 and RT-AX88U are Wifi 6 and not Wifi 6E.I just read it up online, seems like its using WIFI 6 instead of WIFI 6E. Would that be any concern?
Yeah, No Network Access this afternoon. Reset does not help. Now using my 4G data.Anyone have m1 connection issue?
Hmmm ok I think i try buy ROG AX6000 add onYes the spec is also quite a bit better because of faster CPU and 2.5G LAN port.
Not at home now can’t test but I am eager to know this will work not.
Instead of ONT-router-switch
can I do it in this way?
ONT—via WAN switch —router
What is WAN?Not at home now can’t test but I am eager to know this will work not.
You can only pull 1 public IP address via DHCP from M1.Not at home now can’t test but I am eager to know this will work not.
