Malaysia prepaid card
Habrosus
What the best prepaid for internet in JB?
One day, week, or long term?
How much data will you require per day, per week, or long term (daily requirement)?
How much effort are you willing to put in to do the data subscription, do the reload, or watch the card's expiry? How much $ are you willing to spend each time or monthly.
If you've looked at previous discussions, you'd know that no one can give you the best answer to your (vague?) question. Some will give you his/her suggestion based on their own usage patterns, and dealers will give you whatever they're pushing.
My own straightforward suggestion would be go get a DiGi Best card. Why? Coz it's the simplest all-rounder IMO.
kitkat2
Almost. Not for Tron - no roaming option... at least not in SG.
knew someone would raise tron and friendi.
let me rephrase. all malaysian prepaids that support roaming will have roaming enabled by default and no way for you to turn it off directly.
kitkat2
Yes I like their RM1 daily data plan, just need to activate for the few days there and good enough for texting.
rm1 for 30mb, rm5 for 150mb, overuse is 10 sen per mb...ouch!
while singaporeans are crazy over long active periods, i go for long passive period. cards with long active periods come with a higher cost usually hidden in the data rates.
sellbuyboy
long period for keeping the sim, but i go JB only for 1 day shopping.
mainly for grab/uber usage.
Habrosus
Right...
Though OneXOX comes with 28-month validity (subject to T&Cs), I'd say not really suitable for your use, I feel.
I'd still suggest going for DiGi Best. A couple of members here have shared a few times how one can maintain the card if you don't want to pay RM108 for 1-year validity (comes with free data fast and slow), or you can check their website on how this plan works. (Grace period for this is... 75 days.)
Offhand, the RM1 300MB daily data will do for your Grab/Uber usage. I've tried their free basic internet to Grab at Bukit Indah before, and couldn't get the app to work quickly enough. So just subscribe and let them deduct the RM1.
Edit:
See the table here http://community.digi.com.my/t5/Prepaid/Super-Long-Life/ta-p/13004
If you buy now, yours will be Digi Prepaid Best 2017, so one method to reactivate the card during its grace period is to subscribe for 1-day Super Long Life (SLL).
syedafiff
Not with Onexox. Xox does not have pay per use charges. It is either you keep the data or not use the data. The rest will carry forward without any hidden charges.
FYI guys, Xox is the only Telco that has syariah compliance certificate. Meaning that it doesn't burden users with short validity, and doesn't have any hidden charges.
Simply saying, you can use 500MB/30days for cost of rm2.50 only. The remaining data carries forward to be used in any month. Tell me any telco other than Onexox which have 10gb, that can be seperately activated in 500mb/30days, which lasts for 20month for a single topup.
Habrosus
Have you looked into or compared this with Tune Talk's +Vibe?
sellbuyboy
Right...
Edit:
I don't understand SLL 1RM ... can explain further?
what88
If my understanding is correct, you will pay RM1 to subscribe 1 day validity, this will re-activate your DIGI mobile line.
1-2 day later, your line will go into passive/grace period of 75 days.
martintylor
Where to get tron sim card? Even in Meleka also cannot get when I went few yrs back
Habrosus
I tried sometime in 2015/early 2016 but couldn't find as well. It's a few months before that that I came across some Tron promoters in Jonker pasar malam. By the time I decided to go check out the address that they gave, it wasn't open each time I went around 11am.
It's somewhere behind Makota Plaza area, one of those shophouses.
Otherwise your choice would be going through their website, just need to reload a certain amount of RM. Only one I know of that's willing to mail to SG.
martintylor
ya, think thru mail is the only option now
zhiwei_86
hi folks,
i bought the RM20 Digi BEST card, 2gb for 7 days. now left RM4.88 inside, any idea how to prolong the expiry beyond 30days?
theres a RM1 validity extension but for only 1 day.
TIA :)
