MO: DESIGNER PERFUME OIL
swathe
will it go through if minimum order is not met?
thelastname
Deluxe Member
Hopefully will go thru as this time round the MO is opened for nearly a month as compared to the previous times (which is a week). But this time round have more products/choices compared to the previous times too.
If moq of 100 is not met but have at least 50-75 bottles, it will go thru.
thelastname
Deluxe Member
Current orders (unpaid + paid):
5ML - 6/100
10ML - 25/100
30ML - 5 bottles
thelastname
Deluxe Member
5ML - 6/100
10ML - 25/100
30ML - 8 bottles
thelastname
Deluxe Member
5ML - 6/100
10ML - 35/100
30ML - 8 bottles
barleygal
check with you.
the 30ml one is diluted or same as the 5/10ml one in terms of concentration?
thelastname
Deluxe Member
check with you.
I'm not very sure if it's really diluted, but I've tried comparing the sprays and roll-ons and both smell as strong. The spray has a base added so that it can be sprayed as the oil itself will clog the nozzle and unable to be sprayed.
If you want, I can double check with my supplier and get back to you again? :)
thelastname
Deluxe Member
yep, help me check then i'll decide to the the 10ml or 30ml one. thanks.
I've checked with the supplier. Concentration is different. The roll-on has a higher concentration and spray got a lower one so that it can be sprayed.
If the concentration of the spray is as high as the roll-on, it won't be able to be sprayed. Nonetheless, both have similar Lasting and scent power. :)
