MO: DESIGNER PERFUME OIL
snopcool
emailed you the order...
on a side note anybody here managed to find good denatured alcohol to mix the perfume?
thelastname
Deluxe Member
I've gotten your order. :)
I've just researched that denatured alcohol is not good as its not even meant for rubbing on the hands as its added with a lot of chemicals. So it probably would be better to use other high percentage alcohol :)
verionater
Hello
Is the list posted on 1st page all that are available? I am looking for some that are not in ur list, will u be able to get?
thelastname
Deluxe Member
Hello
Yupps. Whatever that is on the list is available. I won't be able to get it if it's not on the list as it requires mass qty to produce a different fragrance on the supplier side.
thelastname
Deluxe Member
Last bump before sleep~
65 more bottles to go~​
Whizdom
any chance on getting abercrombie and fitch perfume which they used for the store?
thelastname
Deluxe Member
Guardian got sell isopropyl alcohol and glycerin BP. Can get them to try to make spray :)
