How are you getting the actiontec adapters to work.
The specs say it works only >1GHz but all the splitter I see are <1GHz.
I tried with the existing <1GHz splitters but the adapter is unable to grab an IP address. It blinks and tries to do something and then goes off and this repeats on and on.
Can anyone confirm they can get the actiontec adapters to work? Did you change all the splitters to <2GHz?
For the actiontec device, the specs listed are:
Network Center Frequency Range 1150 ~ 1500 MHz
Network Frequency Range 1125 ~ 1525 MHz
Thanks
I wanted to use Homeplug initially, but my ONT/Router is on the Yellow Phase, and my Living Room was Blue Phase! The only route is to go Moca.
I have been using 4 units of Moca 1.1 for the past 4 years able to achieve 90mbps. The Actiontec MR424WR support VLAN as well, serves me well as MioTV uses VLAN20 and Smart TV uses VLAN10.
this is how it goes:
SCV Main Inlet ==> 2 WAY Bi Spiltter (5mhz-2ghz) <==Moca Adapter<==Ethernet
2 WAY Bi Spiltter (5mhz-2ghz) ===> 8 WAY Spiltter (5mhz-2ghz)
8 WAY Spiltter (5mhz-2ghz) ===>HALL/ROOM/STUDY Wall coaxial outlet
HALL Coaxial Outlet ===> 2 WAY Bi Spiltter (5mhz-2ghz)
Ethernet <== Moca Adapter <== 2 WAY Bi Spiltter (5mhz-2ghz) ===> SetTopBox ==> TV
It has a total of 8 Channels of frequencies with security password protect.
No way the signals going to leak out to Starhub, anyway their incoming signal is way stronger.
