MS surface pro 4 in singapore?
evq
I use outlook 365 and it “not responding “ quite often when I do email search. Do you experience the same issue? Other than this issue, it’s a wonderful piece to have.
I using 365 outlook too, but I nvr try search before. What u searching? Let me try
todayisgood
search for keywords on subject, sender. not just me, my colleagues too. i dont remember having this issue when i was on Dell laptop. thats the cons. the auto change to tablet, pen are really good features, and its so thin to slip into my bag when i travel. weight is the same though...
evq
I did that type of search before, no issue. How big is ur pst file? I keep mine within 2GB. If over, I just create another file n segregate them
sqgator
hi. my younger brother is going to uni end of this month to study politics. i want to buy him a laptop and tablet separately. i am looking between microsoft and apple. can you recommend me which brand, which model to get him and why?
in case anyone want to flame me why I am choosing these 2 brands please understand that I never studied well. my brother has a chance to be in uni. i want the best for him so i only am looking at these 2 brands. thanks.
Doesn’t matter, just don’t buy a MS notebook, want MS system, buy a HP, Dell, or ASUS.
chenaz
Laptop is enough . No need tablet
watzup_ken
Laptop, I recommend looking at other brands. Tablet, get Apple iPad.
albruby59
I Can't access start menu and taskbar after reset my surface pro4, Pl help!
albruby59
Yes, nothing happens, but I have solve the problem by send to sls to repair and pay for $50, thanks.
evq
care to share what they did to solve it?
evq
I don’t know how they solve also, what they told me my set was infested by viral and need to reinstall the os.
I encountered this problem once after i did a factory reset (I didnt have this problem last time during reset). the Windows button doesnt work when i clicked it. This was immediately after the reset, no other software installed at that time.
I reinstalled with a copy of Windows 10 Pro downloaded from MS, it recognised the license of my surface pro itself & activated without problem.
albruby59
I also try to reinstall another copy os, but fail after restart and go back to problem system again,
albruby59
how did they know the key
Sent from Samsung SM-N960F using GAGT
I have try to reset the system several times and the system only ask for the key one or two time,
and I think they reinstall another copy windows,
Melsolut
Hi,
Does anyone experience battery drain even when the SP4 is turned off? It drops from 100% to <25% in a week.
I have:
- pressed shift when clicking shutdown
- turned off connected standby
- turned off fast startup
yooooz
Hi,
I have:
Yes me too
slsquare
Just submitted request for exchange... Quite fuss free I must say. Just need to convince them it is hardware problem only... With video..
PowerBB
Hi,
I have:
how do u do this? I tried pressing down the shift button n then shut down but it just shut down.
