Need advice from fitness experts
idrinkecoke
Can this type of built at home with home workout? Or i h ave to hit the gym?
DanielBrah
only if you are dedicated and lots of equipments at home.
not just a pair of 2kg dumbbells obviously
idrinkecoke
is 20kg dumbbell good enough?
what kind of physique do you get from pure dumbbell training?
gkhchay
if you are going to just use dumbbells, you need min:
- 3 pairs of 30kg dumbbells for a start
- a foldable bench
- doorway chinning bar
This will probably last you for 3 - 6 months after which you'll either need to join a gym or build a well equipped gym at home that will include:
- a power rack
- Olympic barbell & plates
idrinkecoke
Is it true that doing dips and pull ups are better off than doing home workout with DB only?
galapogos
Moderator
Moderator
Read the stickies. You're asking questions that have been answered hundreds of times before.
tecnica
why restrict yourself to home only? if you dun want to go to the gym, then the fitness corner at your neighbourhood is free and very effective for those who knows what he/she is doing..
it depends on what you do with the dumbbells.. if everyday bicep curl only then dips and pull ups are comparatively better in order to achieve your goal...
Mr Enigma
Can be achieved at home, but you need some basic equipment. The other important factor is your diet. You can have the best gym, but without proper nutrition habits, you will not get your desired physique.
