Need help with Monitor no HDMI issue
gambit_declined
Hi all,
Hoping to get some advice with an issue I'm having for my first build.
I've just finished building outside the case, trying my first boot up and connected my monitor to GPU via HDMI. However monitor is unable to detect any video input (shows a 'No VGA signal, going to sleep in 5 minutes' message).
Tried to find a HDMI port on my motherboard to test if this same issue happens with onboard graphics, but it seems that my mobo only has a VGA slot.
System specs below. Please advice.
Monitor: Dell S2316H 23" 1080p 60Hz W-LED (AH-IPS)
CPU + Mobo: Intel Core i5-4460 + ASUS H81-GAMER
GPU: Asus Strix GTX970 4GB
PSU: Superflower Leadex 550W Full Modular 80+ Gold
RAM: Kingston HyperX Fury DDR3-1600 CL10 8GB Dual Channel Kit (Red)
HDD: Western Digital Blue 1TB
SSD: Samsung 850 EVO SSD 250GB
Case: Corsair Carbide SPEC-02
DVD Drive: Samsung 24X CD/DVD Writer (OEM)
IceCreamPoop
Hi all,
bro your system quite similar to mine, i using same graphic card(different brand) and same monitor and psu. At first i couldn't connect as well. What you need to do is to connect your graphic card and monitor together via hdmi. When you've done that, go to your screen and select input via hdmi. If it still doesn't work.....well.....im out of ideas :s13:
gambit_declined
Thanks for the advice!
How do I go to the monitor selection screen though?
This is my first boot up but so far can't even get to bios :(
kandinsky
Your monitor should also have a VGA port. You can remove the GPU and try mobo to monitor via VGA?
I think he meant the menu options on the monitor itself. Can toggle input source, although usually it should be auto detect but no harm checking.
Check the manual page 15-17:
http://downloads.dell.com/Manuals/a...ay/dell-s2316h-monitor_User's Guide_en-us.pdf
1. Set the Input
On most Dell monitors, there is a Quick Access or Input button This button allows you to change your monitor to the selected inputs, such as VGA, Digital/DVI, display port and various other video input sources that your monitor may have.
Press the Quick Access or Input button to change to the correct video input source.
http://www.dell.com/support/article/us/en/19/SLN128890
gambit_declined
I've updated the input source from auto detect to HDMI, still no result.
The monitor now shows 'entering power save mode'.
Apparently the monitor supports either HDMI or VGA input. I guess I'll go get a VGA cable and test it out.
Just concerned that my GTX has a faulty HDMI port though. Anyway VGA is a downgrade from HDMI too.
