NTU/NUS/SMU 2015-2016 Intake
xyyyyyy999
Sigh NTU too.. What's the chances of appeal for the 3 unis when you're rejected? I'm so lost now..😥
hey mind if i ask what's your rp and what courses di you apply for?? in the same state as well and i guess... the only thing we can do is appeal and hope for the best!
Nosferato4
bce/b b for gp, a for pw and chinese, olevels raw 8, I applied econs for NTU
your A level score is as follows:
Ranking Points/UAS witout MTL: 70
Ranking Points/UAS with MTL: 72
Your A level Ranking Points: 72
IGP Ranking Points for NTU Econs : 75
Difference: -3
even though your results are definitely below the bottom 10% mark (10th percentile) I suggest you go and appeal because you are still close to the cut-off.
Likewise, for other unis if you are unsucessful go and appeal too!
if all else fails, u can choose to retake A levels if you are a guy during NS or ask your OC/JC tutors to write you a stellar testimonial to increase ur admission chances next year.
(NUS and NTU are wayang at a "national level"so a testimonial/ recommendation letter from SAF or any other govt org. will definitely help differentiate u and other borderlime cases)
Also take this time to read up on current affairs, ur poly studies and do reflection to prepare for ur appeal eassay/interview if you are shortlisted!
If not do ur best to catch up n try again next year!
nightzsky
anyone know those who got offer from ntu chem? may i know their rp? pls..feeling damn worry now.. :(
Gowhek12
I used the mobile and laptop to check both can't :(( I'm on Apple products. Are u android? Maybe it's Apple. Idk 😫
I just called up NUS they said they are still in the midst of rectifying the problem and I was told to check back Tmr.
schoolboyz
My sugg is in case ur appeals are not successful try to apply for those courses with cut-off at around 65~73 from NTU nxt yr. I'm sure u can get it if u are not a foreigner :)
wisdomthoughts
ntu sociology
hi guys, is an interview compulsory to all applicants for sociology in NTU? have not been called up for an interview yet..
alianagrande
may i know wats ur rp? :( still no news from ntu..but my frens already starting to receive rejection letter from ntu...
just got my rejection letter. i don't know whether to be shocked or not, because my cut off was borderline without mother tongue, but higher than cut off by 2 points with mother tongue. next thing for me to do is appeal, though idk if i should try to appeal for my initial choices...
nightzsky
i see..my fren called to ntu and ntu told her that just appeal to wat she like.. i guess should just try since after 2nd june, there will be empty spaces in ntu.. i still waiting for my reply from ntu now but i think most likely will rejection letter :( i already appealed..T_T i appealed to cs...a popular course..sigh...
