thanks! was your 6 sem higher or lower than your 5th sem if i may ask?![]()
It's higher by 0.03. I think they only see your 6 sem only if u appeal or apply next year
MSE is my first choice. And I am a foreigner without o lel. Maybe that is the reason. Which poly u from?
anyone got offer from civil engineering or material engineering?
Don't worry, they don't take it into account for giving you the acceptance, they just need to see it to make sure you've passed all modules in your 6th sem.
Hi anyone with around BCC/C grades heard from any uni for interview etc already??!
Hi. May I know which application no. did u use to log in? ( ntu or nus)
Hi!
I used NTU application number. I believe if you are offered from both school, you could use either NTU or NUS application to see both offered. (my assumption). Would need those with 2 offered to clarify.
I was from NYP![]()
anyone got NTU EEE offer yet? btw i received call from SMU ISM to go for interview next week....
I would like to ask if let say I got offered first choice but I actually I just found my interest which is the third choice. Is it possible to make a switch?
first choice from polyMay I know your ISM is the first choice or what?
Think you need to write in to the admission for change of programme. I suggest you wait for the results first before changing.
If you are still in NS, you may want to apply again next year. However, please note that if you failed to change course due to some reasons. Your current offer will be given to other student.[/QUOTE
Thanks for the suggestion. I think I will accept offer first to secure a place first then I will change after that
Did u attend any interview for MSE? Quite worried since I haven't get any news from them
My results almost the same as yours and I haven't received any calls/emails for interviews yet![]()
(My NUS application just changed from "Application received" to "Application processing" today)
