[Official] Cree Flashlights Interest Group
magnus
magnus
Not sure. The uv , warm white and red on the side should be more useful and practical.
Do take note that got cree and nichia version on the main led.
Any idea what use case does the blue and amber side-lights help with?
joesph
I bought nitecore tip SE from shopee, looks original? S$33, shipping S$1, used 90¢ coins 90 coins, about a week come from China
Check out NITECORE TIP SE uses 2 OSRAM P8 LED 700 lumens dual-core metal key light and built-in rechargeable lithium battery, does not include USB charging cable at 47% off! $34.98 only. Get it on Shopee now! https://shopee.sg/product/134180571/5043679473?smtt=0.0.9
nitecore lights Singapore $59. new subscriber to newsletter -$17, still haven't shipping $6
Tip SE small like thumb drive
Sent from Samsung SM-G980F using GAGT
magnus
Nitecore P20 was my first proper flashlight...going to replace it with the latest P20i.
Gixxerfied
I'm still using my Nitecore P10 from years back...
Now redeploy for cycling use..
jack-320
Education for all
Also why the decision to buy proper light
The_King
Hi all,
nitecore and klarus have release new flash light.
which one for all arounder, which i can use power strong light for long duration or low light as needed
https://www.klaruslight.com/Products/XTSeries/832.html (Luminus SST-70)
https://www.klaruslight.com/Products/XTSeries/XT21X.html (CREE XHP70.2 p2)
https://flashlight.nitecore.com/product/p20iuv (Luminus SST-40-W)
https://flashlight.nitecore.com/product/mh12s ( Luminus SST-40-W LED)
https://flashlight.nitecore.com/product/p20i (Luminus SST-40-W LED) i think p20iuv is newer then this
thanks
The_King
here the real run time of the brand i shortlisted.
ACEBEAM L35:
Nitecore MH25S:
Klarus XT21X
magnus
Hi all,
thanks
there is a new nitecore flashlight
The_King
any idea can it hold the higher setting (mostly is the temp that force it to step down) till the battery flat?
give it small size i dont think it can hold it. if that the case ACEBEAM L35 can hold 1.3he till battery flat
