[OFFICIAL] Taiwan Guide and Taiwan related matters - Part 8
calkel20
Ask someone lick for chu...
U should try putting your lips on a metal pole in winter.
Loads of miracle.
Best if you lick it with your tongue.
Andrew833
example of unknown ota?? :o
but i think those in top search shld be fine ba
You are wrong, those on the top search mostly are unknown ota, the price usually very cheap.
Only pick hotels.com, booking.com, agoda and others famous ota. Just pick whichever is cheaper.
Takagi
Ok. Trivago, hotelscombined n expedia also okay right
figo16
TW is dryer than SG, you will feel your face very dry after 1st day there.
depends on the season. TW is drier during winter but more humid than sg during summer.
LIN_JOEL
Is it ok to wear shorts and sandals in Taiwan January?
Will get weird staring or not ar?
1xtreme
I think the weather at Jan will be very cold. But if you think you can tahan the coldness, then it doesnt matter what you wear loh.....
figo16
Not possible.
Loads of stares.
Asian country like that one. i wore shorts in adelaide during winter and weather was around 17 degrees. nobody gave a fark. i wore shorts in hk during december winter when weather was 22 degrees and everybody kept staring at me.
