owndays PC lens vs Crizal lens
mark2k
Essilor is the parent company of Crizal, they're the world's largest provider for ophthalmic lenses with a dozen brands under them Essilor brands
Personally, I've tried several types of lenses, transitions, polycarbonate, CR-39, Owndays etc... I can related to lacquerine's experience, as I've always found that the Owndays lenses seem to give me quicker eye-fatigue, and I've relegated them to a backup pair of spectacles.
I've owned 3 pairs of Crizals now and have no complaint whatsoever other than it's high cost, but it really warrants the quality. I have astigmatism on top of typical myopia but my $300 pair of Crizals never seem to give me any form of fatigue, worth every dollar over my $100 pair of Owndays. It may be cheap, but it might be the lens aspherical properties, material properties or various combination of factors that give my vote towards Crizal (by Essilor). ;)
eeLsinneD
of all the blue reduce lenses, which one reduces blue light most?
Owndays' blue lens very reflective. Was always joked at by friends during mahjong and poker sessions and colleagues could tell I was "Apple+H" my internet browser when they enter the room
Just by looking at my glasses +_+
eeLsinneD
My frame is Owndays' AIR series, super light and flexible till it is hard to be bent out of shape (great for reservist or NS use, pity I bought it during the last years of my Reservist cycle), so I think that will be my frame forever unless I lose it
Yesterday went JB made a pair of new Transitions. Cost RM$380 for my pair (176 and 250 degrees). Way cheaper cos over here it'll over over S$250-$300+.
And just now I took my glasses off (abit skeptical wanted to check it the lens really transitional +_+) and noticed got Crizal logo watermark.
Thought it's some flaw or the lens was some sort of display lens, went to check with Google just now. End up it is just some proof of authenticity.
Overall I am pleased with it.
Swiftyz
Can sic the place to make specs in JB? Planning to get my first anti blue light specs! My future will be staring at computer for hours and hours. Time to take prevention care first
jeff79
There are softwares and apps to reduce blue light. Most new phones have built in blue light settings, win 10 have night light. The anti blue light lens and setting will made everything yellowish and distort the colours. :( Not to be use for colour accurate work.
Swiftyz
You just saved my money! :s12:
klarklar
owndays charge $100 extra for computer lens. Any place to get cheaper? Or are owndays PC lens worth the money because of the higher quality?
paul02
This is interesting as I am facing similar issues with my Ownday's lens. I feel the fatigue and/or have a slight trouble focusing on words when reading.
Renzokukenz
can you buy Owndays frame then go else were to get Crizal lens???
sorry revive old thread but I looking at lenses now
Owndays Blue Light + anti fog = $200
crazy expensive for lense
will Crizal cost around the same?
Windowlover
It computer glasses useful to solve blur images ?
On/off find images blurs when looking on laptop like few hours, does it help with it ? On the other hand, if using external monitor just feel fine..
Joe Maya
got antifog ar?
wow brb hoot now.
occifer
Whatever special coating used on crizal for those fancy stuff, I can assure you that after some time, the coating will wear off, and you'll end up getting smudges, dirty, foggy etc.
Any shop can re-apply the coating?
snip82
I think most of the lens is quite good, my feel is zeiss lens have better clarity, cruzial I have like 3 years can see it start yellowish seem like peel or something but not affecting viewing previously like 7 years ago.. since then i get zeiss lens.. more impt is the frame.. nowdays so call branded frame does not hold well..
I have lindberg, I use less than 6 month the so call screwless hinge make from acrylic break , i repair for 180 dollar, then continue use another 8 month then accidentally small knock it break again..
After that I use oakley as least can last 3 years above before it OOS for repair, it abit more tough.
If you are a rough person better dun buy those oliver people or lindberg or switch out to cheapo spec when doing rough works or sport
raj2677
Just to check Oakley frames can be repaired? I have some paint peeling on the front of the frame.
snip82
If under warranty maybe plus if their product is still in production.. u can check back with the optical shop u purchase from..
From my point of view the serviceability of frame from all the brands usually is not like TV repair or electronic or even like watch.. their product life is very fast off the shelf after a year or 2..
eeLsinneD
Confirm can. Been there done that. Once locally, another time changed lens at Holiday Plaza at Johor Bahru.
Owndays' blue light lens is very reflective. Someone in front of you can see if you are surfing the net at work or what your mahjong tile is just by looking at your glasses.
Really what happened to me.
