PC made some sound and auto restarted
Luc777
boot up and went into windows
keyboard and mouse lights out
pc made some "di di di" sound and rebooted
not even seeing the windows logo rebooted again
a black screen with the stats of my pc appeared
eg ssd, hdd, sata etc
only 3rd time then it started up successfully with the start windows normally screen
dont know is it me or does the fan inside sound like its struggling more than usual?
can anyone advise me on which part might be failing?
thanks and sorry if my description is not clear enough
jtjt00
2 self-check you can try:
1. memtest86
2. HDTune error scan (uncheck quick scan)
3. Remove the side panel and see if CPU/GPU fan struggling to rotate?
Luc777
1. memtest86
ok i got the memtest
i running the hdtune now
got a few drives to run, so i think will take up some time
will do the memtest after this
thank you
