Recommend monitor, psu, casing and also comment on Rig
dragonbryan
Hi all my computer died on me and I'm looking to buy a new com hopes people here can help me with it.
Think of setting up as below, hope you all can give some comment and also recommend monitor, psu and casing.
Rig used mainly for surfing YouTube and webpage, playing game (mainly LOL but want to be a bit future proof for other games) and watching movie.
Total Budget about $2500
Processor and MB: ASROCK Z170 extreme 7+ with i5 660k ($784)
Gfx: Sapphire R9 380 ($365)
RAM: Ripjaw V 3200Mhz CL 16 ($245)
Hdd: 3TB WD Green 5400rpm 2+1 year warranty ($143)
SSD: Samsung Evo 850 m.2 250gb ($169)
Need help with
PSU: budget about $150
Casing: budget $150
Monitor: budget about $500
lalalalalala
CPU cooler: nh d15 <- need advice
Need help with
Casing: budget $150
I'm looking to get a similar build this black Friday.. I shortlisted similar components, maybe u can take a look and consider
Processor and MB: ASROCK Z170 extreme 4+ or Asus z170 -A with i5 6600k ($637±$2)
Gfx: gforce 970 ($488) waiting for promo, dont really care about brand
RAM: cheapest single stick 8gb ddr4 ram ($90 to $100)
SSD: cheapest 250gb ($100)
PSU: currently researching/need advice
Case: currently researching/need advice
Monitor: currently researching/need advice
With your budget can probably whack a gforce 980 for gfx and a higher wattage psu
Sent from OnePlus A0001 using GAGT
dragonbryan
I was thinking 980 too exp and a bit overkill. Anyway the mother board i chose apparently if i fix 2 pciE cards then both would be running at X8. R9 380 needs x16 to run right? Anyone knows?
monikernemo
Xn (where n is a integer) refers to how many pcie lanes an expansion device is taking up.
While modern day gpu runs at PCIE 3.0 16X, they can run fine in 8X but there must be a physical 16X slot in the first place.
Skylake CPU has 16 PCIE 3.0 lanes. For dual graphics Xfire/sli (if supported by mb) will split to 8x 8x.
Though 8x technically has 1/2 the bandwidth of 16x, current gen gpus not capable of exceeding bandwidths of 16x 2.0 (technically same speed as 8x 3.0), so no concern.
Anw 380, 3TB WD Green seems like a bad purchase option. Maybe a 970/390 would be more fitting for your budget? Then monitor we can keep to 1080p.
Psu prolly a Superflower Leadex Silver 550W @ 110 Casing wise, either Enthoo Pro, or Fractal Define R5 @ 169. Check out Lazada for discounts? Monitor maybe a U2414H for 1080p? One of the best you can get already. If looking at higher res, 1440p, only U2515H fits the bill within that price range unless looking at Korean monitors (qnix, mango)
Sent from JARVIS using GAGT
dragonbryan
Thanks for your input!!!! Why is the hdd a bad choice? Then what options are better? Which 970 would you recommend? Sorry I have not touch diy com for 10 years liao lol
MoneyFace =p
Need help with
Casing: budget $150
$2.5K can get top-end GTX 980 Ti le wor....
Jian19
if u not overclocking need k chip and z board ? do u think u need those features anot...
i5-6500 + Asrock h170m Pro4 ~ $470
Kingston 8gb ddr4 ~ $88
Samaung 850 evo 250gb ssd ~ $169 / $139 (Lazada)
Wd red 3tb ~ $173
Msi gtx970 armor oc ~ $530
Superflower leadex 550w 80+ gold ~ $139
Samsung oem drive ~ $24
Fractal Design R5 ~ $169
Win8 64 oem ~ $135
Dell u2414h ~ $329
$2226 buy and assemble @ pctheme ask for discount.....
Gtx970 enough for ur gaming need, and dun bother to think about crossfire or sli...if u wan to pump a crazy card top up $450 and get Palit gtx980ti jetstream @ $999 @ Lazada
MoneyFace =p
Full Black & White Themed
CPU+MB: Intel Core i5-6500 + MSI B150M BAZOOKA @ $448
RAM: Corsair Vengeance LPX DDR4-2400 CL14 8GB Dual Channel Kit [Black] @ $120
GPU: MSI GTX 970 4GB ARMOR OC @ $530
Ask for white version.
SSD: Samsung SSD 850 EVO 250GB @ $129 (Lazada Singapore)
HDD: HGST Deskstar NAS 3TB @ $158^ (Lazada Singapore)
PSU: Super Flower Leadex Silver 650W [80 Plus Silver] @ $109^ (Lazada Singapore)
CASE: Fractal Design Define R5 [Black] @ $144* (Lazada Singapore)
OS: Microsoft Windows 8 Professional 64-bit Product Key [OEM] @ $28 (Reddit)
Upgrade for free to Windows 10 via free Windows 8.1 update.
DSP: Dell UltraSharp U2414H 23.8" 1080p 60Hz W-LED [AH-IPS] @ $339
Total: $2005
Optional:
GPU: Zotac GTX 970 4GB Twin Fan OC @ $478
GPU: Palit GTX 980 Ti 6GB Super JetStream @ $974* (Lazada Singapore)
DSP: Samsung S24E370D 23.6" 1080p 144Hz AMD Freesync W-LED Wireless Qi Charging [AD-PLS] @ $365 (t258jgn)
Buy others from PC Themes, #04-15. Haggle for discounts!
In-Store Promotion
*Price after Lazada App MasterCard Monday / DBS/POSB Appy Friday / CITIBank Wild Weekend 15% off max $25 discount [TBA later]
^Price after Lazada App $20 off minimum $100 discount coupon [TBA later]
dragonbryan
Wd red 3tb ~ $173
Win8 64 oem ~ $135
Dell u2414h ~ $329
No lah I dont OC but thought of having a more future proof system whereby over time I can change the parts as and when required mah. Plus I thought the components used in those boards are better quality thus probably can last me much longer. Dunno if I am right on this.
MoneyFace =p
More expensive board = more features included = more points of failure. Even top-end ASUS ROG motherboard can fail within first 3 years. A simpler motherboard with decent quality components will reap you better outcome.
Jian19
high end board failure rate also same with entry board one...
for ur usage a i5 can last a long way liao...
dragonbryan
Ah I see. Thanks for your input! But those different types of capacitors really got different??
dragonbryan
Agree agree, even my AIO from HP that bought about 3 years plus back to me still very good enough, only thing is the parts are failing so I thought why not just change a com and building from scratch instead of buying from these companies I probably will have more flexibility. Hope the new com can last me 5 years or more
