Recommendation: Reliable workshops in JB
myviowner
oh he got sell tires also ar? i planning to also change mine too... but quality and stock fresh ma? my boss from malaysia tell me to do in sg better cos malaysia alot of chiong one also....
Yeah... Listen to your boss....Change in sg.
Did he also tells you EO many fake ones in MY too:s13::s13:
snipfer
Really need an alternative audio/accessories shop option than Sheng Auto. Yet another time yesterday when I was in JB and despite waiting for 3 hours+ they had no capacity at all.
Can try Kings Motorsport, someone posted good reviews here a few months ago. Moreover it's just opposite the cheap and good dim sum
Or this one recommended to me by gosford leather boss. Both I have yet to try.
Pung Auto Car Accessories Sdn. Bhd.
No. 1, Jln Sagu 15, Taman Daya, 81100 Johor Bahru, Johor, Malaysia
+60 7-354 1732
https://maps.app.goo.gl/fUsd8
Sent from Xiaomi MI MAX 2 using GAGT
YorYor
Cool, thanks. Will go try them out if Sheng Auto really unable to make time during my next trip in.
myviowner
TT Motorsport pricing no good. Customers mainly sinkies.
Tried them on the UR bars... Cheaper than SG price. And few JB workshop too. Cos near to custom/ KSL area??
Did my homework then settle with them.
leeslayerex
Thanks bro will call up Jackson
You can try Sheng Auto. Call Jackson up to check if they do only exterior only or dismantle whole lamp and do also the interior.
YS Head Lamp Recondition Services in Selangor....:eek:
Bro here had did with them before if i rem correctly...
jfkoh
+60 7-354 1732
Near King's motorsport if this is also full.
elegant auto sound accessories & air cond service
Also not bad in term of price. Boss friendly also.
Sent from HUAWEI EVR-L29 using GAGT
VenomSpeed
Anyone can recommend a workshop to raise a car that is too lowered? Been scrapping the carpark humps.
YorYor
Thanks guys, been browsing Google Maps to identify some possible options too. Will probably give one of them a chance and see how much they quote.
IloveEmma
Hi All,
Want to get those dash cam hard wired to car battery.. should I get in MY or online and bring it to carclick or workshop to fix?
Any recommendation for a good reliable part if buy online?
snipfer
Hi All,
Carclick is a workshop. Accessories go to accessories shops like Sheng Auto
snipfer
Change back to stock suspension.
Carclick
myviowner
Hi All,
1. Sheng Auto in JB. Get everything from him. He carries IRoad
2. King's motorsport. Search them in FB. They carries Thinkware
3. Buy a used set over carousel and get it done either at Sheng auto or sg. SG installation charges not more than $100.
Last time did mine in SG, dekit and installed the same 2CH dash cam @ $80
Final decision is yours.
koolaid
Ah yuan got do GTI golf MK5/6 or Sirroco ?
anyone saw before?
i ever saw him worked on a bmw when he was still at lch. if its the usually servicing, it shouldnt be a problem. call him and check?
Leave No Men Behind
These wat I saw like few weeks back-1st visit.
myviowner
anyone saw before?
As bro said, normal EO change/ fluid change should be fine. They would send to another workshop to reset the maintenance interval if don't have the equipment.
Else, below is what one frd used to go during his VW ride days:-
HL CARECARE CENTER SDN. BHD
73, Jalan Indah 16/12, Taman Bukit Indah, 81200 Johor Bahru, Johor, Malaysia
Contact Alan @ +6016-776 5933
slothbal
Please Help to Advice
Hi,
Does anyone have a workshop to recommend to fix this issue? TIA!!! :s12::s12:
" border="0" alt="Image and video hosting by TinyPic"></a>[/IMG]
snipfer
Need to change the rubber seal. Get it from stockist then go to accessories shops
