Recommendation: Reliable workshops in JB
funky05
If we change 4 new tyres , how would be the subsequent rotations be? Front to back , left to right or X ?
weeza77
Surely depends on tyre thread construction. Directional?, Asymmetry/Symmetry?...
koolaid
I planning to replace my headlight units. I’ll provide them the parts.
o ok. i think its quite a straight forward job n i believe most accessory or workshops should be able to do it. may be u can try sheng auto or carclick? contact them first before going over.
koolaid
all 4 tires same size? if so, i usually do this during oil change.
front right to rear left.
front left to rear right.
rear right to front right.
rear left to front left.
snipfer
Yup front to rear.
No point changing front left to front right as the front tyres wears out the most
Sent from Xiaomi MI MAX 2 using GAGT
funky05
Yea same size.. Thanks bro!
razakyasin93
Ok thanks bro! Will call them up
SuperSprint
Best to change one pair then all four.
Usually change front that wears out faster.
Been doing this
Jeaniuz
was quoted power steering flush for 170rm, is that chopped price ? never done before even in sg so not sure of the market rate
snipfer
Don't need to flush unless yours is a COE car
Check with ah yuan at Carclick
koolaid
i think its reasonable. i think in sg, it'd probably cost you from sgd80, depending on the make n model of your car.
have u gotten quote/s from any sg wksp?
myviowner
SG workshop quoted you?
First time heard flushing steering fluid system... :s22::s22:
Leave No Men Behind
liquidh
It is important to change all sorts of fluids regularly. May not need to flush. But definitely need to change.
