paintballz
- Jul 22, 2010
Guys any WS in JB can do car spray whole body Matt colour? Good workmanship and price?
Carclik. Chek them on FB and the contact is there.Anyone did ATF flushing in Johor before? Can share the price & location?
Assume ws did a proper job and didn't screwed up your car..
Change whole radiator. Buy from stockist only $150. Labour $50.coolant leak i think there is only a few place to check. hose pipe, coolant tank itself, radiator, water pump, thermostat.
Suspension is layman term. Shocks absorber si bo? Gas or oil? Don't forget to check absorber bumper ok? Bushes too ok? Check absorber mounting ok? And stablizer links too. All in if you know will cost you just $800. Go workshop ah...$1.2k you just get 4 absorbers flat..nothing else. Slowly learn ok.do u mean sgd1.2k to change all 4 suspension in sg? iirc labor in sg is probably > 200 to change all 4. have u checked with stockist on the cost of all 4 suspension?
Buy yourself. Parts will cost you abt $400 to $500. Labour $50 each side. Get all the bushes too...abt $9 each...if u know how to buy online ..$2 each.hi guys, am driving a 2011 hyundai elantra. Previously went to a workshop and check my engine out + ask the technician to help check the suspension as it has been making noises when being compressed (going over a hump), and very stiff feel.
Got quoted a full change of front and back suspension including the arms and stuffs @ 1.2k for OEM version. just wondering if any bros / drivers here has experienced similar events and gotten a change of items in JB?
Thank you!
Standard servicing package, repairs but balancing outsourced to other tyre shop.Rambo at KSL can do standard servicing package? And balancing?
You can try the autobacs opp ikea. They do carry a far bit of jap parts, including blitz air filtersyah but i finding a particular brand of grounding. Sun Auto from Japan.
thats why asking around here
Thanks!
18" rims cheaper in sg.is rims cheaper to get in SG or JB? 18". lightweight prefered.
Any recommend workshop in jb for installing the part we brought in sg? Thanks in advance.
Sent from Xiaomi MI 9T PRO using GAGT
Ignition coilWhat are the parts you are replacing? Can let u know the labor charges I paid in JB if I did it before. Had bought quite a lot from stockist in sg, and replaced them in JB
Any recommendation to do dechrome?
Thanks in advance
Sent from Samsung CURVED UHD S8 using GAGT
15" and below, Johor cheaper
Ignition coil
Engine mounting
Shock absorber
I diy for ignition coil so dunno how much. Labour to replace 4 engine mounts about RM $100 to $120.
Labour to replace all 4 shock absorbers, mounting, stablizer links, bushing & damper about RM $150 to $200. The dust cover & big spring seldom need replacement but u can swap the left n right spring.
Usu I go around jalan dedap, rosmerah, seroja area near Giant Plentong. Find a workshop that quote you around that price can go for it. Avoid workshop too near the custom, usu very ex..
thanks i will try it,![]()
