Recommendation: Reliable workshops in JB
Catboy
Wow.
Thanks for sharing.
Yes. Care to share which workshop n how much? And also the down time they took etc?
Thanks!
So suggest u check your parts first before replacement. Maybe some are still good. Get a mechanic or go YouTube learn how to check
Now can only remember it's in Jalan Seroja area, dun have exact address. I replaced the rear shock system first then the front, each time about 100rm labor and takes less than half a day so total like 200rm plus. Go ask around workshops in Dedap, Seroja, Rosmerah areas and avoid those too near the custom. If they quote u around that price, can liao.
robotman12
Hi, does anyone know which workshops in JB specializes in Mazda cars servicing? TIA
robotman12
it's not just changing EO and that's it, there's a list of other stuffs to check for every 10k servicing, like change a/c filter, check coolant, check suspension etc.
Going back Mazda TEK for these is too ex nowadays, just want to know other alternatives out there.
myviowner
If you had that expectation that workshops in the north follows what is practicing here in sg, then personally i suggest you visit sg workshop instead.
Over in the north, they would conduct the usual points checks (lubricant checks, air filter removed and air blow and under carriage.) Then perform road test. They don't have a check list on clicp board while going around checking the ride.
If you read couple of comments posted earlier, you would know how workshops in the north carry out their job.
Got leak/ faulty then change. Anything related to safety, change. Can tahan till next servicing, then change on next servicing.
Gerald1408
Ok thanks.
RayOfLight
any recommended workshop that does normal servicing and spray paint server? need to respray front bumper.. quoted 100+ to spray half and 300+ for full in sg
liquidh
Just go Hup Seng at Sin Ming. Old uncle very reasonable.
dps_code
thanks for sharing bro.
i recently bought a 2009 avante, want to install reverse cam, and android player to replace the Pioneer player.
Any recommendation? any recommendation in JB that also sell these so one shot can settle?
myviowner
Sheng Auto, is popular in this thread. Find them in FB. Contact Jackson @ +60167035250, about your intention and ask him for a quote.
Make a booking before go down.
myviowner
Read thru earlier posts. There are few alternatives mentioned. For me, i still stick to Sheng Auto. Also Jackson can do air con related repairs.
savoirex
changed ATF, engine oil, oil filter and air filter at bt indah. labour cost is RM50. is the cost okay?
liquidh
Wah that is super cheap. Unless the mechanic marked up the costs of oil, ATF, filters etc.
savoirex
I bought the parts in sg including engine oil and then brought over...10yo kia forte, many things start to breakdown. rike aircon leaks, engine mountings, ignition coils.
guess I will need to visit more workshops so trying to find a cost effective one...
myviowner
Is super cheap on the labour. I change eo and filter, the workshop i frequent charged me RM30 on labour le.
myviowner
Yeah... test water on few workshops and offer your reviews here... Sharing is caring.... lolz
savoirex
not much of a review, cos the eo and atf change job was pretty straight forward.
the mechanic used a pump to remove the old atf which was brownish-black. then poured in the new pinkish-purple fluid by hand...removed drain plug below the engine, then filled new eo by hand. all this was done without ramping up the car lol...then he drove to a level ground and check all the dip sticks...
