Recommendation: Reliable workshops in JB
yanbros
I'm not sure how much he charges to do chemical wash on conderser but i feel for 650, its overcharged. Did he give you breakdown? Mind sharing?
mrkerpalz
i forget to take receipt.
but he did breakdown for me.
still ex?
kweeli
still ex?
so rm650 is almost just workmanship + coolent?
My ws charge me labour rm 10 for engine oil chance but no flushing. My own eo n filter.
yanbros
still ex?
If you can post a rough breakdown, then can determine. It might be the coolant that's ex in the first place. So if you have a rough breakdown, I can roughly give a gauge on what's overpriced.
mrkerpalz
Things done @ Jet Auto
Flush Engine (Their Product+drain out the old oil with a big machine) + top up with new EO. (my own EO)
Flush ATF (Their Product+drain out the old oil with a big machine) , top up with new ATF (3 cans of suzuki 3317)
Flush Their Product+drain out the old oil with a small machine+ Bleed Brake oil, top new BO (my own oil)
De-carbon throttle body with a "funny looking" gadget with a de-carb spray can thing.
chemical wash aircon "condenser" or cooler
drain coolant + top up new coolant. (my own coolant)
Snowblind
My jb servicing comparison Which I felt was abit ex.
Engine oil, my own oil and filter
Drain and top up coolant, my coolant
Adjust timing belt, was misaligned by previous workshop
Change thermostat, my part
Change water pump, my part
Change radiator tubing, my part
Change radiator cap,their part
Wheel alignment and balancing
Rm 450
I believe ur de-carbon thing is close to 200rm as I enquired about it at another jb shop. How is ur aircon, better after the servicing?
Solidus_GZ
Is the gearbox oil use yours or theirs? I think your gb oil could be the one which is exp.
sinicker
my guess is the flushing items are actually by themselves RM300 around there right?
but hey, just bought 2nd hand car... for that price is quite worth it.
if you walked into a workshop in Singapore and earnestly say you just bought this car, i'm sure your bill will be much higher with all the things that they want to do to your car. so take stride in that. :D
Snowblind
Agree on the Singapore workshop. I initially went to one workshop in sg. Few days later noticed the engine temperature is not going up. Went to the same workshop and he say maybe leaking radiator. How can the radiator be leaking when the coolant level never go down and it should be overheating. Quoted me sg400 to do check flush radiator and does not included any repair or parts.
I checked forums and YouTube only to find out that it might be the thermostat or sensor. Changed the thermostat and all is well. The rm400+ I paid for soo many items in jb is not even half of wat he quoted for dismantle and inspect. Also changed the engine oil after 3k since I didn't trust this fellow already. And he misaligned my timing belt due to the vibration which I felt after the belt change.
Solidus_GZ
Ok la 650 rm is a small price as compare to what you pay in workshop here. in my earlier post, the sg work shop quoted me 550 sgd jus for labour
whereas jet just do it for 450 rm and I'm very satisfied with Job done
Rxgn
any reliable place near ksl to do tinting of mirrors and accessories?
Eternalglory
anyone know a good paint touchup shop and dent repair ?
Ask lots of uncle, all lazy to do the job because is a minor scratch or dent.
tian_cai007
Anyone knows where to get the parts for back LED light? And which WS in JB is able to change the LED? Many thks!
croc1977
Moi first time out of Agent
Everytime spend $2xx ~3xx at agent cos 5 year warranty ......
98k liao ...wanted to try sg but this morning past by this shop with liquid moly....actually wanted to put coolant addictive nia...
but....
Liquid moly servicing plus addictive...RM$444...
croc1977
then they check found my ATF dirty ...say recommended change
RM$180
Spark plug carbonize.
RM$180.
even my spark plug only change around 70k nia....
then also say even change but better clean throttle cos very dirty ...alot of carbon....
pour this in here
need to flush out
Expensive??
i know liquid moly in sg around $130 can do service but other than all these nonsense i no idea the price
saggice
JB servicing can be done within 20 mins, Singapore will take one whole day!!
hahaaa...
