Recommendation: Reliable workshops in JB
Solidus_GZ
Ya lo
My tyre balancing I do 5RM per tyre Leh
In SG where can find?
BenBen010103
Any recommended shops in jb for brake stuffs? such as rotor, pads and ss brake hose? Looking to change there and get the parts there and then. Care to share location and what brand they carry?
Oh ya btw I'm looking to change to those after market slotted rotors.
Any shops in jb for change of amaron battery too?
Thanks!
stompwarrior
Buy parts in SG and service in JB. Even Mobil 1 engine oil got fake in JB. The JB mechanic in JB told me himself and even advised me to buy parts and engine oil in SG instead.
BenBen010103
Thanks!
No one have any workshop to recommend?
Rxgn
then they check found my ATF dirty ...say recommended change
RM$180
Spark plug carbonize.
RM$180.
even my spark plug only change around 70k nia....
then also say even change but better clean throttle cos very dirty ...alot of carbon....
pour this in here
need to flush out
Expensive??
i know liquid moly in sg around $130 can do service but other than all these nonsense i no idea the price
singapore, toyota wish i change atf already $80.. your price is $60..
front brake pad $60
fan belt $90
yanbros
top speed doing exhaust only?
They specialise in exhaust but do repairs as well. Had a friend who did a engine overhual for his BMW. Another civic did servicing and belt replacement. Like your typical workshop.
CadburyChan
Any advise if i wan to install car security system in malaysia? Is it cheaper and reliable or not?
deeda13
Hi all,
Was thinking of going to try out Jet Auto as most bros had recommended..
One workshop in Sg says my power steering pump leaking. Need to change.
Should I buy from SG and bring in to change by Jet Auto? And also do a basic car servicing check?
Don't they have Honda parts to replace say (my power steering pump) ? Would it be cheaper?
Sorry for all the questions.
Hope anyone can enlighten me.
Kamsiah Kamsiah.
sinicker
Hi all,
Kamsiah Kamsiah.
what car are you driving.....
trex101
I'm driving an Honda Civic. 2009
Usually parts are cheaper in Singapore compare to JB but 2nd hand parts will be cheaper there, just ask the JB mechanic and compare both prices.
That is why we have a lot of Malaysian customers coming to Singapore and bought engine oil back, even they themselves are afraid of imitation and rather buy it from us.
deeda13
Thanks for your valuable advice.
So I supposed one has to make 2 trips to the JB workshop.
1st time to service car and see what needs to be replaced.
2nd time to bring parts from Sg and let the mechanics in JB fix it up.
Am I right?
Leave No Men Behind
Instead of double trip. I would suggest let them do everything..for major service. If only basic.. can just get oil, plug, filter, coolant such and move in.. I did my tyres there too. Not bad.. The workmanship..
sinicker
sure Jet Cheng can do one...
up to you whether you wanna buy stuff from stockist (Thian Seng) and bring over. Jet and his father doesn't mind.
he has EO - motul. RM180 for an oil change. this was in june 2014. maybe now increase. other brands also have.
PM me if you have queries.
now my car under warranty so cannot go back to him yet. his place, if there are 4 cars there, 3 are Singapore cars....
shank118
Going JB tomorrow guys. Any workshop to recommend for fixing my front speakers? They aren't working, and the sound is only coming from the back.
sinicker
try ah wee along jalan dato sulaiman.
but if only a fix, why need to go in?
they might rather you buy something from them and they install for you..... this way their inventory leaves the shop.. rather than just fix everyone's problems... how to operate business....
