Recommendations for 27inch monitor
Gr3yham3
Not sure whether this is the right place to post, but my 27inch LG monitor which I have used for about 5 years is finally showing signs for breaking down - there is a white horizontal line that runs across the whole screen somewhere near the top of the screen. I guess this means that the backlighting for the entire row has failed?
anyway, would like to ask for recommedations for replacement 27 inch monitors. Budget would be below $500, unless there really is a such a great deal of a super good monitor that exceeds my budget. Mainly used for gaming with titles like Diablo 3, Heroes of the Storm, and Witcher 3 once i got time to start playing
enenyi
Resolution? 1080p, 1440p or 4k?
Then u need to decide whether u wanna prioritize budget or resolution.
Gr3yham3
well at the moment my gaming is all in 1080p and that's all my current rig can handle, no money to get a 1440p gaming rig anytime soon, and i think most 1440p monitors are out of my budget anyway .. is 1440p that much of a diff compared to 1080?
enenyi
At 27 inch size, yes. Based on personal experience.
Next question is whether u r okay with glossy screen or u wan anti-glare screen.
monikernemo
Most prolly go for 1080p. You need time to get used to mobas at 1440p. Witcher is a demanding game to drive at any resolution.
There are 1440ps below 500 but quality maybe compromised?
Sent from JARVIS using GAGT
Gr3yham3
hmm well i do sit pretty close to e screen.. havent experienced 1440p gaming in any form so i cant say .. but i guess there is a reason why ppl are switching to 1440p
screen prefer to my non-glossy, but again, budget is more impt.. so to conclude
Monitor preferences:
1. Used mainly for gaming
2. Hopefully around $500, but i can extend it if the monitor is really worth the money
3. 1440p will be great for future upgradability
4. matt screen preferred, but can live with glossy (lucky my room light can be adjusted to orange light n not just white light)
enenyi
Well, I sat at 50cm away from my Philips 1080p 27" monitor previously, and I felt it was barely okay. Go any nearer and I'll start to see pixels, though not that irritating, but well...
At $500 budget, referencing prices to PC Themes pricelist, we get:
1) Dell S2715H 27" IPS glossy IPS monitor - $399
2) Philips 274E5QHAB 27" IPS glossy monitor - $409
3) AOC i2757FH 27" IPS matte monitor - $389
Gr3yham3
hmm but these are all 1080p monitors, no? not sure of the current technology, but IPS are okay for gaming now? a few years ago, everything was TN panels for gaming
also, i guess with 1440p, we can pretty much turn off AA options in most games?
enenyi
Yeah, that was a few years ago, when IPS technology was still expensive, 27" monitors were hard to come by, and LG was still one of the best selling monitor brands in the local market with their 22" and 23" models. :D
All those I've shortlisted are 27" 1080p monitors. And gaming with IPS is no problem. Reason why gamers go for TN panels is coz current monitors that support 144Hz are mostly TN.
If u still want 1440p, u got to make a compromise: either pony up more money to buy 27" 1440p monitors like the U2715H selling at $739. Or settle for a smaller screen, like U2515H, a 25" 1440p monitor selling at $529. (Both prices referenced from Fuwell pricelist.)
Gr3yham3
i see.. anyway i dun think my current rig is going to be able to handle 1440 gaming too.. no money to hoot the new gfx and cpu also.. ah well.. i think i rather save e money that will allow me to get a new rig that will let me run witcher 3 at ultra settings@1080p, then to buy a 1440p monitor at twice the price and not be able to afford a rig to run the games at the resolution..
of the 3 monitors, which will be your recommendation? i know the AOC has been around for quite a long time, no?
enenyi
I would recommend the AOC.
But my advise is to make a trip down to Sim Lim Square or Funan, take a look first-hand at the monitors being shortlisted. Then decide which monitor best suits u. Coz ur preference and my preference may differ. Since u will be staring at the monitor most of the time when using the computer, the monitor has to suit your taste and preference in terms of aesthetics. Specs wise, all 3 are nearly identical (except for the glossy vs matte finish), all have 3 year warranty.
majora
Sorry to hijack abit. I'm currently also looking for a spare monitor and dunno which one should I get. My budget is less than $200 and glossy 22/24inch will suffice.
Any recommendation?
Gr3yham3
anyway, will 1440p be able to game at 1080p? will there be upscaling problems?
and should i wait for Sitex?
enenyi
Any recommendation?
Dell S2316H, $209 (Fuwell pricelist).
enenyi
If u can wait, wait for Sitex. Since major retail stores like Challenger and Harvey Norman are gonna bring in monitors by the bulk, u can expect some cost savings there.
enenyi
I forgot. Can your eyes tell the difference ?
At 27 inches and at 1080p resolution, yes. Colours are very different on both types of display technologies. Even more so when u view the monitor at an angle.
Gr3yham3
i think IPS and TN really quite different in terms of the image quality.. anyway i am leaning towards the AOC also as the reviews for it, though old, are pretty good.. lazada seems to have it, and with mastercard mondays can save a bit also
