Recommendations for a Monitor.
Jkdada
Hello fellow ts,my really rundown monitor have finally give in and broke down and so i'm looking a monitor that can match with my gaming rig and the games i play on my rig like bf4,cs:go,dayz etc... I have a budget of $300 (can stretch a bit if really worth) But am seeing things like imput lags and 60,144 Hz refresh rate and how many ms and so is a bit confused about which monitor should i go for.and also if i shd get it on Black Friday from oversea or get it local in the upcoming IT show. So please kindy advise me on a monitor suitable for my rig and games.
Your help is kindly appreciated.:):)
JihJing
U2414H - this is the monitor that most ppl recommended in this forum for budget of $300.
pedokuma
1) Do you need 144hz monitors? But 300 hard to get decent 144hz monitor
2) How big are you looking at?
3) Glossy or Matt?
300 dollars, maybe can get 2 x Dell 2340L ? Or go for those korean 27 inch monitor.
Need to know what you want and expecting first.
Jkdada
3) Glossy or Matt?
Hmm ill prefer 144 hz refresh rate and sizing between 24 to 27 would be good.
But whats the diff between glossy and matt?
Much thanks
Goodshot
add $35+ for U2414h , u wont regret it . I just send a email to dell for exchange of monitor because dead pixel , they sending in 2 days time .Very fast response , good dell
Steyr69
Much thanks
Yup....this is what i was trying to tell you about....glossy is you see your own reflection at times on the screen. Dell S2340L is glossy. If your room the lighting is behind you....try not to get glossy. Personally i still prefer matte.
Sent from Asus ME173X using GAGT
Jkdada
I see. but im thinking about all the imputs lags respond d times etc..as it mainly be used ofr gaming so ms is important to me
kimsix
wait sitex and see any good offer or not. too bad, dell monitor cant purchase through amazon, otherwise it is much cheaper.
Shipping from overseas the monitor is expensive. Buy from Singapore Dell got good warranty and will swap if you have dead pixels
pedokuma
Much thanks
Matt is non reflective , glossy is reflective. In term of color, of course glossy will be more accurate and nicer which is nice if you do design work. But if you have lighting or window near your screen, will have a lot of glares and reflections, more like a mirror at that point.
I use 1 gloss and 1 matt. Matt for gaming and gloss to watch video/image editing.
Those korean 27 inch monitors, i think most are glossy too.
You go check dell or asus or acer sites then. 23 and 24 inch got some difference in prices, if you want to save a bit, can get 23inch instead. Can easily get the reviews of those monitors online too.
