Redmi K20 Series - The Redmi flagship
SPEED
Just installed the monqiqi screen protector which I got from taobao. Got white corners then use the liquid glue included. Now sibei swee swee. Rocks man this screen protector.
Nakedtoes
Yeah as I said before. Some paste is perfect some might have white border.. But so far the screen area length is longer then actual screen except left and right is covered 0.5mm.
ichinisan
Can share the taobao link for the screen protector?
SPEED
Any idea if the liquid glue will damage the phone original screen? Lol
Nakedtoes
i got put also so far so good.. i squeeze bit by bit... the thing is i scare it leak into the speaker grill on top... ;)
WatCult
Surprised that Mi 9T Pro from HK is supplied with the 3 pin plug while the local Mi 9T Pro is supplied with the 2 pin plug.
davidwong
Why are you surprised? Southeast Asia only SG and My uses UK 3 pin, all other countries predominantly according to population Indonesia the biggest and they are using 2 pin and across SEA most wall plugs accept 2 pin round
As for uk hk, their population and market is big enough for manufacturing a 3 pin for them plus they have tighter regulation than Sg.
Moreover, if you look at the 3 pin plug brick that hk has you will see the middle peg is plastic ie is a fake peg and there is no earth which is electrically or same as 2 pin
Surprised that Mi 9T Pro from HK is supplied with the 3 npin plug while the local Mi 9T Pro is supplied with the 2 pin plug.
WatCult
I understand if SG is part of a SEA SKU and HK is lump together with UK as part of their UK SKU. But UK and HK are different SKU for Mi since their HK back cover don't have the CE marking. SG+MY market should be equivalent to HK mkt. They probably could have done a UK 3pin for us.
Anyway that is just a small complain... not having the 8/256GB version locally is the bigger issue.
whoooo
Oh... I still don't know what the glue is for lol. I applied the SP all swee
Nakedtoes
U are lucky.. I guess is the screen problem.. I pasted 2 also got white border.. But I try this brand i-flexi dun need glue... But the screen size not as good as monqiqi.
Wee1985
Hi. May I know when buying xiaomi phone, is the EIN sticker a Must have? Because a lot seller at online shop selling local set all don’t have the sticker, yet is a local set recognize by xiaomi warranty
Myu~sun
U can try branded clear case like IMAK, NILLKIN and Spigen... they dun turn yellowish that fast.;)
acrylic back doesn't turn yellow . only the sides tpu does . so get those acrylic (hard back) with black sides like ringke series fusion x does the job with a lil added design =D
Myu~sun
i believe its from different distributor . SG Xiaomi set seems alot issue . previously got ppl pass of export set as local set . and sometimes the item is local set but when check with XM its stated as other country.
whoooo
Oh ya I also think I damm Heng, anyway I remove and paste near 20times the SP before finally got it
whoooo
The SP won't catch dirt meh?
Sent from Xiaomi MI MAX 3 using GAGT
Nope, they also have a tape for those ngeow pp like me who paste and re paste to catch the dirt. Also I was in room with AP on so dusty was reduce lol
I using naked except for the SP
Edit add photo
