SAF IPPT, IPT & RT Questions...
justme
anybody go for RT on monday, 24th June, at Khatib camp?
Ns portal update ur attendance already?
vasilli07
How to check this ah ?
Can try booking a non-ict ippt before booking your 1st RT session. If the system allows, then should be no problem. If system don't allow, then should be 3 RT sessions then can book.
Or you can call the FCC or ns.sg to check.
suprememessiah
Hey guys, is it possible for me to scan my IC to in-pro and out-pro directly at the counter on the spot and considered myself as failed ippt or do I have to actually attempt the stations one by one itself ?
you need to attempt before can record as attempt and fail
RabbitKing
if i missed my ippt window, can appeal dont take RT but just take IPPT instead?
edit: first time and passed all the previous years without RT/IPT.. just totally forgotten abt it lol
mgx-alander
didnt attempt at all be prepared to receive charge letter.. :s22:
vasilli07
U will be charged as an ippt defaulter and must go RT. As u are a IPPT defaulter, not sure if u can book IPPT after your 3rd RT session. If no, then u can only take your IPPT on the 8th session.
Adi Dassler
Not sure is it true that now IPT program, they allow us to play football as part of the training?
gallagher
hi,
anyone know how does Kranji ippt system like?
it says 6pm, if late like 5-10 mins, will the guard stop me from entering the camp for RT on weekdays?
Also how long the session normally last at Kranji camp RT...2 hours 3 hours?
Thx!
AceyourMaths
hi,
Thx!
No. 2 hrs.
ItsmeagainhK
bro Vasilli ,
Assuming i failed ippt and my window close. So i need to go for 20 RT. From the 3rd RT i can book ippt so that if i pass i can no need to go for the other 17 ?
When i do the RT booking, they say 8th session is a test. So i assume must be booked as a normal RT ? then when go for the session they will ask us go for IPPT ah ? Normal ippt time start at 5pm , for RT on the same date is 6pm. So i just come at 6pm and tell them i want go ippt ?
PS: first time doing all these nonsense. sigh. Really sian. Failed by 10 sec for 2.4.
vasilli07
bro Vasilli ,
Yes, after 3rd session can book a non-ict ippt if u think u can pass. If u pass, u can stop going for rt.
Yes, 8th rt session also ippt. Go inpro at ippt counter and tell them rt-ippt. Rt-ippt is at 6pm.
ItsmeagainhK
Thanks. That definitely helped.
