SAF IPPT, IPT & RT Questions...
cannonmaster
nowadays FCC guardroom cant find name listed for RT/IPT/IPPT & had to use sms alert on hp to verify?
they should just add on in the alert as another item to bring: a copy of some sort of verification of ippt booking... later those never bring handphone one how?
j_t_fusion
might as well set standard to use hp & ic to verify i/o print out?
HP sms can be easily falsify.
you need another HP to send you a sms in the same format. then in your HP phonebook you just need to put the contact name of that other HP as 36767.
MBBSclinic
but guardroom use this as alternative...:s22:
lankileong
How come got swimming one? People got bring swimming trunk meh?
Yes everyone brought cause we were sent an sms a day before bout it.
Called ns hotline, they are unaware that IPT has swimming incorporated.
It might be a new segment during IPT to test its usefulness of having swimming as a form of trainining.
oddeye82
Hi, I only took 7 ipt sessions and I tried to take ippt last sat but I failed. This afternoon I got a msg from mindef saying I completed my window with ppt met. Wierd....
oddeye82
correct mah... you fail IPPT but hit the PPT.
But from my 1st ipt session result this year or last year ipt band, I should be in the last band which means I should get a pass in ippt to pass the ipt.
PS: anybody knows the point range for all the bands in new ipt system?
j_t_fusion
go ns portal check if it also say PPT met. if PPT met then i strongly suggest you just take it and keep quiet.;)
crow_nest
Yeah the IPT-IPPT session I went at the end of april also like that, the guard ended up asking for SMS or email confirmation as proof.
Anyone going for any session now should opt for the email/SMS reminder just incase you need to show proof upon entry.
dustyRoom
download the ns ippt app to check, but the bands are very low and quite easy to clear. now u complete ipt can riao. They will pass u for effort. no need to hit minimun band.
Sent from within a supervolcano using GAGT
iambehkan
hi guys, just checking that if i'm in RT window now, i can't book ippt and go clear it right?
die die must go for RT and wait for the 8th session which is ippt?
sean29
Injured Wrist
Was playing soccer as a goalie and then overstretched my wrist. Alot of ppl say tendon tear, some say wrist bone break and at least 4-6 months recovery. I havent go specialist check yet but sibei sway cannot train for push up now, my wrist hurts like hell. Got station excuse for that?
AceyourMaths
Was playing soccer as a goalie and then overstretched my wrist. Alot of ppl say tendon tear, some say wrist bone break and at least 4-6 months recovery. I havent go specialist check yet but sibei sway cannot train for push up now, got station excuse for that?
Only with medical letter as proof.
HolyInnocents
There are currently 3 bands in the new IPT System; 1, 2 & 3
Band 1: 0-15 points
Band 2: 16-30 points
Band 3: 31-50 points
These point ranges are for NSmen who are required to do all 3 stations. For those who are excused from static station(s), a different set of point range is available.
Hi, yes you're right. You have to wait for the 8th session before you can take the IPPT.
Hi, a specialist check/excuse is not sufficient to exempt you from push-up station. You have to book a medical appointment with your MO via your unit/NS Portal to officially excuse you. However, a letter from specialist will help with your exemption.
mudxblood
I`m taking my first IPPT as an NSMen in Maju camp next month. May i ask the laojiaos the 2.4km is indoor or outdoor? i.e run a continuos stretch or run a couple of rounds?
:D
:s22:
