SAF IPPT, IPT & RT Questions...
BiG_FisH
anyone knows the IPT timing for Sunday at Khatib FCC?
I can't rmb if it's 8:30am or 9:30am and the portal is down now so I can't check.
Calander
Sorry i meant to ask this time if I would get the incentives for both year 1 and and 0 if i went year 0. Or that if i went for year 0 i wont get for year 1 anymore?
U will still get both for Yr 0 and Yr 1 according to the incentive award system.
Only Yr 0 is not mandatory to clear IPPT window.
Calander
If i never go for FFI and attempt IPPT, what will happen?
if u are age 35 u are required to go for FFI. If i am not wrong the in-pro counter will question u if u have cleared FFI and can even reject your participation for IPPT. As any medical issue if you were to develop during your participation because of that, that FCC would be in trouble.
Cookie Muncher
Just question? They don't have system to check and valid?
Calander
their system should be able to check. nevertheless, they will ask you because they should be able to see from their system and in case the info is not updated.
but whatever the case is, you have to ensure that you have cleared FFI. if i were u, i would be interested to know if i pass or fail FFI because i would have to either clear the window to avoid any chargeable offences or totally be exempted from it so that i can have peace in mind.
doubt u will want to go in-pro and find out that u had actually wasted your time in making the trip down because you failed your FFI or because you have not passed FFI.
Cookie Muncher
Thanks for the advice
matey1982
if u haven't done your FFI, no way you can book IPPT/RT/IPT inside NS portal
then there's zero chance u can just gatecrash @ the FCC
bumdssa
anyone's outpro slip sessions dont tally with actual?
just follow ns portal can alr?
justme
hows the FFI like?
say I got high BP, they refer me to specialist, do I need to pay $?
