SAF IPPT, IPT & RT Questions...
Calander
What is the use of having the IC check when going into the camp if they don't even scan our IC?
They also did not have a pen to tick off those that have arrived on the paper.
Guardroom only verifies that you are the person who had registered for IPT, RT or IPPT. They do not in-pro that is why. As long your name is in the list, you may enter. Or you have a better idea on how they should verify NSmen for entry?
radiancez567
what toking u ah
dont understand u
u refering to at guardhouse?
u try gatecrashing with others' ID
good day good luck and good health
tot tt time there was the news of the person kena caught for cheating at ippt by using other pple's IC to clock attendance to take and pass the test?
Ya talking about the guardroom matching the IC against the paper.
1. Process often not computerised, hence no record who they let into the camp
2. Did not use a pen to tick away those whom they allowed into the camp, often resulting in more time to search for our names on paper.
Hence, on record there's only in-pro timing. From security point of view, there should be record on entry into the camp.
reddevil0728
Suggest you feedback to mindef directly
Calander
"record on entry into the camp".. they can always counter-check with FCC in-pro counters.
if in the event such NSmen cleared guardroom but failed to register at FCC, means that NSman could have went to other areas which are not authorised. In such situation, any personnel on-site has the authority to ask for camp pass and should it fail, the on-site personnel can report for security action.
for your point 2, it does not matter as the names are arranged in alphabetical order. so with or without ticking-off does not matter... but brings more hassle than it require.
Disaresta
Khatib FCC confirmed resuming IPPT on 23rd, running is done at carpark area instead of the track
SuperSprint
Trying to boook ippt, my current windows is RT.
Thursday Maju fcc 1800 is ippt ? When I book never show ippt. Only show RT.
so report at fcc tell them I coming for ippt 1800 slot? Correct.
chehjin
you mean ur 8th session?
tell them RT-ippt.
Songbird
Hi guys, i will be facing an upcoming IPPT default charge. Many times already. Lost count. My last year somehow i managed to act pity and kenna charge $200 only. My question is,
1) will they send u to DB before they charge u the maximum? ($500)
2) What can i do now to on my part to help myself? I do have some medical problem, see doctor get letter ? OR must see a specialist?
3)is there ANYONE or someone here who knows someone who actually went DB for IPPT defaulting ?
My hope is that since my last fine was only 200, MAYBE they will still give me 1 more chance or something..coz i think by right DB should be the last resort, after they have done everything they can to you but you still dont want go ippt THEN they will throw you inside right ?
lastly i advise all those who are suffering from IPPT laziness to get just get it done..once a month RT also can... now really regret liao..
flowerpalms
no need to think about anything now.
you just prepare to clean ur butt and go in and squat!
numbers
Can dropout halfway for 2.4? Is it still counted as attempted?
if drop out half way, no count, attendance no count also.
If really cannot liao, just walk, at least clock the attendance. Walk like senior citizen speed also can.
plsaskme
Thanks for the reply from both seniors. Just to clarify, as long as I complete 10 IPT sessions means I've fulfilled my current ippt requirement for this window right?
Calander
correct.. regardless pass or fail the IPT-IPPT.. just clock attendance will do.
LEUMAS
anyone unable to log in to ns portal??
Sent from Samsung SM-G955F using GAGT
avi6274
Me too! Sometimes I can't log-in and when I do I can't access the RT/IPPT page...
Changing browsers and clearing cache does not work. On tuesday it still worked on the mobile site at least but now even that is not working. FML...
LEUMAS
Same... Zzzz. I successfully log in but the page still shows the log in button without my name. Can't access anything and the online live chat staff doesn't seem to know anything. Zzz
triface
Hi all, first IPPT coming up soon after ORD.
Are all the FCCs using machine counting for pushups and situps? Always did at NSTI or SPS Camp in Bedok and they were all manual counting. Got a feeling my results will be cui now that it's machine :s13:
forefore
Didnt complete RT, when will the letter come?
So i failed to complete my RT for my current window due to poor planning and heavy school work.
This is my first time, what should i be expecting? And when will the letter come that tells me to report to cmpb?
