crimsontactics
- Nov 25, 2009
Hi Bros, just to check with you all why nowadays like unable to book Monday IPTs?
Sent from . using GAGT
No slots liao
I'm going IPT next monday and friday should be their OFF day
But I see most Mondays also no slot...Erm ...what i mean is they fix every Friday as their off day not because of holiday or eve.
I got a letter from NSAD that due to Covid19 there is no HSP so I am exempted for IPPT for my window.
However when I see my NS portal it states I still required to take IPPT.
So listen to whose instruction?
Hi, if my unit waive my IPPT requirement (My window closes after 7 Feb but unit waived on case-by-case basis, I was informed of the waiver from my DYS8 through Whatsapp) will they sent a official letter informing me that my IPPT requirement is waived or just the whatsapp conversation between me and the unit DYS8 is enough for black and white? Thank you.
No. IPPT fail or not doesn't matter.first time doing ipt, for those with experiences. if you do 9ipt session and the 10th ippt you failed do you have to do RT?
I think currently 1st IPT session is no longer an IPPT session.on the 10th ipt session which is a IPT-IPPT, pass or fail doesn't matter.
However on your 1st ipt session which is also a IPT-IPPT and if you pass, you do not need to attend the remaining IPT sessions.
Now 1st IPT session no need to be IPPT liao.Anyone knows if first IPT session can request to be IPPT on the spot? my window closing this month and no slots for IPPT all the way
